Fuel Surcharge
Discussion in 'Ask An Owner Operator' started by Tex909, Jun 3, 2007.
  1. Tex909
    Tex909 Bobtail Member
    5
    Thanks Received:
    Jun 1, 2007
    I am starting a new company with my brothers, how does the fuel surcharge work?
  2. truckinpa16
    truckinpa16 Light Load Member
    66
    Thanks Received:
    Apr 27, 2007
    rochester ny
    its basically a charge to your shipper if the rate of fuel goes above 1.25 per gallon i have a number i will be able to get to night if u would want it that you call and it gives you the surcharge for the region then u multiply that by the miles of the trip
  3. Tex909
    5
    Thanks Received:
    Jun 1, 2007
    I would appreciate it.
  4. BearGator56
    BearGator56 <strong>"The G stands for GOOD!"</strong>
    280
    Thanks Received:
    41
    Apr 11, 2006
    Atlanta, GA
    Since we'll never see $1.25 a gallon again, I would try to make a rate based on current fuel prices. I created a formula that is based on my truck's MPG's and CPM. If you can come up with a per mile rate that will cover your costs and the customer agrees to, then a fuel surcharge may not be necessary.
    In any case... Here's a good link to help you:
    http://www.tbabz.com/AssessingFuelSurcharge.htm
  5. truckinpa16
    66
    Thanks Received:
    Apr 27, 2007
    rochester ny
    tex the number is as follows call and follow the step by step instructions i believe diesal is number 1 then it gives you the rate for your part of the country just run it by how many miles the trip is and then multiply it its not gonna seem like much money but it will help some what 202-586-6966
  6. BearGator56
    280
    Thanks Received:
    41
    Apr 11, 2006
    Atlanta, GA
    Here's the link that goes with that phone number. It's the Dept. of Energy:
    http://tonto.eia.doe.gov/oog/info/wohdp/diesel.asp
  • Draft saved Draft deleted
