I have a second truck that I've been babysitting until I clear up a few things with it and today I went to move it to cut my grass. Well there was no power at all. Nothing on the dash lit up, no air buzzers, etc... I was gone for about 2 weeks and had it running warm before I left...
I had to leave the house to go finish this load I'm under but I was looking for some pointers or advice on troubleshooting... I didn't leave any lights on or anything like that... Though once I get it back running I need to make sure there wasn't a light under the bunk or something that may have been on...
My plan when I get back is to test the voltage at the batteries with the key on... 2nd, take the batteries out & take them to NAPA and load test them... Check for grounding issues... I know there's an oil leak @ the cam followers that is leaking basically right over a stud on the frame that is used for grounding 4 or 5 wires... ((This will be corrected b4 the truck hits the road)) ...But I just drove the truck 1500 miles home no problem about a month ago...
Any tips or pointers would be greatly appreciated. Thanks in advance and safe trails
Got No electricity... No power to start, no On the dash,
Discussion in 'Ask An Owner Operator' started by HopeOverMope, Aug 21, 2016.
Page 1 of 3
One bad battery will drain 3 good ones in that length of time. I would start there, hook up jumper cables and see real quick if dash lights on before anything.
NavigatorWife and HopeOverMope Thank this. -
I assume you have 4 batteries and you talking about cam followers I assume it's an old cummins so it shouldn't matter which one. just hook to cables and you should have headlights, a dome light, anything. That will verify a battery issue or that something was left on.
HopeOverMope Thanks this. -
Had this problem with a 1995 KW W9 just last week. turned out being a main circuit breaker inside the battery compartment had burnt out. It's a main breaker that powers everything in the cab. Guy at the KW dealer said this was a common part to fail. If this is a KW of the same vintage, I'd check that first.
I had this happen recently, and the culprit was a fusible link that had chafed and welded itself to a metal bracket. Could be any hot wire doing it, but in my case it was a fusible link
tommymonza and HopeOverMope Thank this. -
Any more pointers or tips?Attached Files:
Page 1 of 3
