Grain Hauling - How Much Per Mile?
Discussion in 'Ask An Owner Operator' started by newbe, May 16, 2011.
  1. newbe
    newbe Bobtail Member
    Thanks Received:
    May 16, 2011
    my friend and i want to haul grain most from one elevator to the other (a common thing in south dakota) but would like to know what other people charge per mile so we don't over do it or under do it.
  2. hawkeye42799
    hawkeye42799 Light Load Member
    93
    Thanks Received:
    22
    Jan 28, 2007
    iowa
    i do the same thing but i do it for someone else and i get paid by the hour and i go from elevator to elevator or to customers
    so i would be interested to know what ya find out :biggrin_25519:
  3. newbe
    Thanks Received:
    May 16, 2011
    mind if i ask how much you charge for a general idea
  4. hawkeye42799
    93
    Thanks Received:
    22
    Jan 28, 2007
    iowa
    no clue what the company charges but with all the crap i have to go through it aint enough
  5. BIGMIKE1
    BIGMIKE1 Light Load Member
    257
    Thanks Received:
    82
    Jan 23, 2010
    If your hauling for the elevators it will be cheap, and they will tell you what there going to pay you.
  6. BigBadBill
    BigBadBill Bullishly Optimistic
    4,526
    Thanks Received:
    4,141
    Oct 2, 2010
    Chattanooga, TN
    Off-season in IL barely covers overhead but you have so many farmers looking to get something/anything from expensive equipment that barely gets used a month a year. So you are looking at a true over supply vs. demand. Some farmers will even run at a loss when you add driver pay as it is a cheaper way for them to keep someone employeed year round.
    As far as rates, it will likely be on a per bushel basis based on a mileage band. So you have to load heavy to make the most money. And be carefull to not listen to guys that tell you that DOT wants to see that you are under gross and axel weight is less important. No state has the ability to override the laws on federal highway.
    Last year during harvest with fuel rates about $1/gal cheaper guys saw between $5 and $6 per mile with the ones with good relationships with the transportation manager getting much better than that.
    What I would suggest is to get a van or a flatbed and haul that during the off season then follow the harvest around and get 2-3 gravy months.
    Admin Thanks this.
  7. Add a truck driving job review
  8. Prairie Boy
    Prairie Boy Road Train Member
    2,961
    Thanks Received:
    1,574
    Nov 18, 2010
    Edmonton, AB
    The best rate structure is always by the hour. Otherwise, establish rates on a Ton Per Mile Basis. Use a Minimum number of miles at all times in your rate structure.
  9. Cowpie1
    Cowpie1 Road Train Member
    4,673
    Thanks Received:
    3,517
    Nov 25, 2008
    Kellogg, IA
    BigBadBill got it right. The rate on grain hauling is on a per bushel loaded rate. You have to load right on up to the top if you are going to make it worth while.
  10. 66truck
    66truck Light Load Member
    122
    Thanks Received:
    20
    Nov 7, 2008
    ohio
    I know a guy that does it here in Ohio and I think he told me he was paid around .20 or .25 cents a bushel. He runs hard and heavy, buys a new hopper trailer every couple years because of it. Ive been told rates arent all that great because of all the farmers that own their own trucks these days.
  11. wheathauler
    wheathauler Trucker
    2,030
    Thanks Received:
    577
    Mar 10, 2009
    Hutch, Kansas
    You are correct. Most farmers own multiple trucks and trailers around here.
  • Draft saved Draft deleted
