2008 intl prostar , cummins isx , 1,3 million km
Ive been wanting to do the DPF delete and havnt gotten around to do it ...now im paying for it ...truck is in California .... 2000$ this week and still broken down
broke down Wednesday , dozer injector code and egr codes , installed new injector, broke down 50 miles later with a low oil pressure warning.
changed the oil pressure sensor and made it 100 miles and again truck shut down. oil pressure reads 32 psi which is normal ...
im leaning towards the egr valve acting up and sooting up the oil , the last oil change was 27 000km ago . but this truck does some idleing...
so im thinking of disconnecting the egr and doing an oil change to see if that works ...i need to get this truck home...
ps ive done what you've suggested in your thread ... imap sensor ect ... about 200 000km ago
your thoughs would be appreciated Heavey d
your t
Heavy D need Help
Discussion in 'International Forum' started by jameson1985, May 23, 2015.
Nasty weekend to be broken. Good luck.
Thanks ! I will need the good luck !!!
The intake manifold pressure sensors can plug up quickly. I would recommend to look at it again. The egr differential pressure sensing tubes also get plugged up along with the ports in the venturi pipe. Those need cleaning/replacement as well. Another sensor that triggers problems without any codes is the exhaust back pressure sensor. If it is more than an few years old, I recommend to replace it.
double yellow Thanks this. -
When I first read the title of this post I thought it said HeavyD needs help. Was worried for a moment about Heavy.
Heavyd Thanks this. -
LOL, I do need help, but nothing you guys are qualified for!
Don't we all my friend. Don't we all!
Heavyd Thanks this.
