HELP! N14 Celect Plus shutting down...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CbarM, May 23, 2013.
  1. CbarM
    CbarM Heavy Load Member
    898
    Thanks Received:
    234
    Jan 17, 2011
    Irvine, AB
    Hey guys, I have a 98 Freightliner COE and it started running really rough as I was parked. It would drop to 400 rpm n then the governor would shoot it up to 800. It would bounce back and forth a couple times n then die. If I leave it shut off for 10-15 mins it starts good, runs good n I can drive about a mile before the same problem happens again. If I restart it right away it starts sputtering right away. Coolant, oil and batteries are good...any ideas??
  2. Worthken
    Worthken Light Load Member
    265
    Thanks Received:
    76
    Jun 2, 2012
    Delmas South Africa
    It sounds like a fuel issue. When last did you change the fuel filters? When a Cummins hunts like that, it usually has air in the fuel.
  3. CbarM
    898
    Thanks Received:
    234
    Jan 17, 2011
    Irvine, AB
    The fuel filter was done about a month ago. It sure seems like a fuel issue but why would it run good for a few mins after being shut off for a while?
  4. j-dawg
    j-dawg Light Load Member
    164
    Thanks Received:
    41
    Dec 21, 2011
    Oil town, Ab
    The #1 injector is shot. It controls the timing. If it's faulty it will shut the engine down. To test it take an ohmeter and check the leads to the injector. No ohms, the injectors shot.
  5. Worthken
    265
    Thanks Received:
    76
    Jun 2, 2012
    Delmas South Africa
    It could be a fuel pressure issue, I'm thinking the fuel filter is collapsing causing a restriction. Any loss in power before the shutdown?
  6. j-dawg
    164
    Thanks Received:
    41
    Dec 21, 2011
    Oil town, Ab
    It starts and runs fine until the injector gets warm, then the solenoid won't respond, the ecm times the engine off the #1 injector. That's why it shuts down. I had it happen last year to a N14.
    Worthken Thanks this.
  7. Add a truck driving job review
  8. CbarM
    898
    Thanks Received:
    234
    Jan 17, 2011
    Irvine, AB
    Hmmm...could this have anything to do with my overhead last week where they said they adjusted my injectors?
  9. CbarM
    898
    Thanks Received:
    234
    Jan 17, 2011
    Irvine, AB
    The last time I had it running I was just gettin up a lil speed n it died right away...no sputtering...kinda like turnin the key off...
    Now it just turns over but will not fire. Got a wrecker comin...what a pain in the rear...
  10. Smellfunny
    Smellfunny Medium Load Member
    645
    Thanks Received:
    193
    Jan 28, 2012
    South Carolina
    You need to hook it to reader and see what (if any) faults are in the ECM.
  11. blanco
    blanco Road Train Member
    1,220
    Thanks Received:
    279
    Nov 20, 2009
    Gwinnett County, GA
    Have u checked the ecm + lead at battery box?
  • Draft saved Draft deleted
