Help No brake lights
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Jan 3, 2012.
  1. brenes-built
    brenes-built Light Load Member
    157
    Thanks Received:
    10
    Apr 14, 2011
    Vancouver, Wa
    Okay just got the truck washed and now I have no brake lights... Everything else works turns and running lights.. Both tractor and trailer have no brakes... Where do I start looking? It's a 99 pete... Thanks :biggrin_25521:
  2. TennMan
    TennMan Road Train Member
    6,554
    Thanks Received:
    7,032
    Sep 21, 2011
    Hazzard County Jail !!!!!
    Check your fuses sounds like a short caused brake fuse to blow.
  3. brenes-built
    157
    Thanks Received:
    10
    Apr 14, 2011
    Vancouver, Wa
  4. TennMan
    6,554
    Thanks Received:
    7,032
    Sep 21, 2011
    Check and see if the pig tail has water in it at both ends if connected to truck that way.
  5. TennMan
    6,554
    Thanks Received:
    7,032
    Sep 21, 2011
    do a quick disconnect of the pig tail and see if the tractor brake lights begin to work. if so it's either the pig tail or a trailer issue.
  6. brenes-built
    157
    Thanks Received:
    10
    Apr 14, 2011
    Vancouver, Wa
    It has to be the truck...because still no lights with the pig trail unplugged from trailer...
  7. kalh7
    kalh7 Light Load Member
    184
    Thanks Received:
    60
    Mar 28, 2007
    southern illinois
    might be the brake light switch. if im thinking right it is behind the plastic dash pieces behind the pedals. should be labeled saying what the switch is for as there is more than one. i would think the only way to check the switch is to make sure you have power to one post than apply the brake to check if power to other post.
  8. TennMan
    6,554
    Thanks Received:
    7,032
    Sep 21, 2011
    Yea sounds like the relay switch. Behind the brake pedal
  9. Bill104
    Bill104 <b>Pepsiholic</b>
    719
    Thanks Received:
    764
    Dec 27, 2011
    Sacramento,Ca
    And be sure to use a light tester on the fuses, sometimes they" look ok but there not
  10. bender
    bender Road Train Member
    2,105
    Thanks Received:
    1,296
    Jul 20, 2010
    Don't Kid Yourself
    Should have separate brake light switches and relays for tractor and trailer.
    Brake lights will only operate with ignition key on.
    Does the truck have a maxi or mega fuse panel under the hood?
  • Draft saved Draft deleted
