Help with 2 active faults pls
Discussion in 'Freightliner Forum' started by ptwn1, Oct 25, 2012.
  1. ptwn1
    ptwn1 Light Load Member
    93
    Thanks Received:
    10
    Oct 4, 2012
    Hi i have 2 active faults on my truck its a 2002 century with det 60 10 spd. The first fault is eng low 128s214 01 I looked it up they say its a ecu problem and the only way to fix it is to replace the whole ecu is it true?? And my second fault is brake wh snsr axl 2r open 136s004 05. I want to know what is this problem and how to fix it if anyone can help Ty.
  2. Pablo-UA
    Pablo-UA Road Train Member
    7,525
    Thanks Received:
    1,443
    Oct 11, 2010
    Borispol, Ukraine
    real time clock is powered with small 3.6 v battery. It is Li battery used for ECM life. In electronic shops it is possible to solder new battery in and with DDRS you can set the clock
    SID 004 FMI 5 - broken ABS sensor wire, right rear wheel (you have Wabco ABS-E 4S4M system)
  3. ptwn1
    93
    Thanks Received:
    10
    Oct 4, 2012
    Ty for response yea I found the problem for the wire In rear axle it's cut inside the drum somewhere I'm gonna fix it when I change the rear tires I can't get to it without removing the wheels but for the other fault I think I'm gonna leave it alone cause I heard it doesn't cause any problems for the truck. Does anyone know how to erase fault codes?
  4. Pablo-UA
    7,525
    Thanks Received:
    1,443
    Oct 11, 2010
    Borispol, Ukraine
    freightliner dashboard reads codes as active, so fix cut wire with heat shrink and ABS code dissapeares
    Engine ECM code may be fixed in electronic shop. If you ignore bad clock battery it may leak acid and damage ecm iside. To desolder battery find shop with infrared solder station and ECM body heater, becouse if to heat battery only if may blow spiling acid on film and ECM be damaged out of repare
  5. ptwn1
    93
    Thanks Received:
    10
    Oct 4, 2012
    the wire is cut deep inside the drum i think i gotta wait till i remove the tires to get to it i hope i can just put them back together
  6. Pablo-UA
    7,525
    Thanks Received:
    1,443
    Oct 11, 2010
    Borispol, Ukraine
    Replace ABS sensor.
  7. Sgtmike
    Sgtmike Bobtail Member
    7
    Thanks Received:
    Sep 2, 2012
    Yes by all means replace the Abs sensor. Do not splice it back togeather! The Abs light will still remain on until you clear the active fault and then drive the truck a short distance. Make sure you check the air gap between the sensor and the exciter ring before you put the brake drum back on.
  8. Pablo-UA
    7,525
    Thanks Received:
    1,443
    Oct 11, 2010
    Borispol, Ukraine
    push the sensor back with ring carefully to get minimal air gap but do it carefully to avoid ring be bent
  • Draft saved Draft deleted
