holland 5th wheel slack adjustment help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by doublew, Mar 6, 2011.
  1. doublew
    doublew Light Load Member
    68
    Thanks Received:
    4
    Oct 17, 2010
    Kansas
    i have a holland 5th wheel with the adjustment bolt/nut that sticks out the front i get alot of bang when ya hit the brakes and bang when ya hit the gas can the slack be adjusted out with that bolt ??
  2. SL3406
    SL3406 Medium Load Member
    321
    Thanks Received:
    248
    Jan 10, 2011
    Oklahoma
    Back the nut off and it will tighten the jaws on the fifth wheel.
  3. doublew
    68
    Thanks Received:
    4
    Oct 17, 2010
    Kansas
    great thanks thats what i was thinkin but wasnt sure
    thanks
  4. 123456
    123456 Road Train Member
    10,434
    Thanks Received:
    5,457
    Oct 22, 2010
    32179
    if'n you don't know how to do that,
    I'd pay somebody !!!!!!!!!!
    You CAN get in trouble messing with that adjustment, just a FYI.
  5. mitchtazz
    mitchtazz Road Train Member
    1,734
    Thanks Received:
    420
    Sep 6, 2009
    Lake Wales, Fl
    yes it can, and it's an infinite adjustment also (at-least until the bolt is backed off to the point where there's no more thread). to adjust it, just unhook from the trailer and back the bolt off, then hook back up to the trailer, and tighten the bolt back down to the fifth wheel plate. keep in mind that when you tighten the bolt back down, you should still be able to spin the rubber washer (the one between the bolt and fifth wheel plate) pretty easily with your fingers. if you can't spin it then the bolt is too tight and needs to be backed off a bit.
    if you still get the bumps and bangs when ever you take off or stop, then your fifth wheel may need to be rebuilt, or the king pin on the trailer needs to be replaced.
  6. 123456
    10,434
    Thanks Received:
    5,457
    Oct 22, 2010
    32179
    Very Good,
    and the instructions ARE available online.
  7. mitchtazz
    1,734
    Thanks Received:
    420
    Sep 6, 2009
    Lake Wales, Fl
    yep, and the rebuild is easy as pie, the hardest part for me was unmounting the fifth wheel so i could flip it over to do the actual rebuild. there's not many parts to it.. the bebuild took alot of the bang out, now i'm considering replacing the king pin on the trailer or just waiting to get a whole new trailer.. it depends on how much it's gonna cost to replace a king pin, haven't gotten any quotes yet.
    good luck.
    123456 Thanks this.
  8. 123456
    10,434
    Thanks Received:
    5,457
    Oct 22, 2010
    32179
  9. rbht
    rbht Heavy Load Member
    888
    Thanks Received:
    496
    Jan 23, 2010
    CT,NH
    Just make sure you get it correct. I've known quite a few people that have adjusted there own 5th wheel only to loose the trailer the next run not to far down the rd.
    123456 Thanks this.
  • Draft saved Draft deleted
