how can i overide the engine shut down on a 2012 cascadia
Discussion in 'Questions From New Drivers' started by jefflouk, Jul 10, 2011.
  1. jefflouk
    jefflouk Bobtail Member
    10
    Thanks Received:
    Jul 10, 2011
    Hello,
    I'm trying to find out how I can keep the engine from shutting down. I have a 2012 Freightliner Cascadia.
  2. Bent Wrench
    Bent Wrench Medium Load Member
    583
    Thanks Received:
    188
    Aug 11, 2009
    Cornholio, OR
    It's easy if you own the truck, however if you don't own the truck there will probably be a password issue.
    BigJohn54, jefflouk and gpsman Thank this.
  3. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,973
    Thanks Received:
    1,538
    May 13, 2011
    SW Missouri
  4. ironpony
    ironpony Road Train Member
    17,502
    Thanks Received:
    11,850
    Sep 23, 2007
    Ask my GPS...
    We have an "ENG SHDN OVRD" - Engine Shutdown Override switch on ours... you've got 30 seconds after the red engine shutdown lite comes on to hit it. Will run for 3 minutes I think. Its not to run very far, but just enough to get you to a safe place to park and shutdown.
    You're real issue is why the ECM thinks you're killing the engine...
    kee1227 Thanks this.
  5. jefflouk
    10
    Thanks Received:
    Jul 10, 2011
    I am leasing the truck right now.
  6. THBatMan8
    THBatMan8 Road Train Member
    1,478
    Thanks Received:
    459
    Feb 13, 2011
    Wherever I park
    If your truck has a manual, read it. There are a few ways to over ride it:
    1) Press on the OVRD ENG SHDN switch
    2) Rev up the RPM's
    3) Turn on the cruise control to put the truck in smart idle mode.
    TruckingJohn Thanks this.
  7. Add a truck driving job review
  8. ironpony
    17,502
    Thanks Received:
    11,850
    Sep 23, 2007
    Ask my GPS...
    And get the #### truck looked at before you do some serious damage to it.
  9. jefflouk
    10
    Thanks Received:
    Jul 10, 2011
    When I'm. Parked at a truck stop where it is hot I would like the engine to stay on instead of shutting down after 5 minutes.
  10. Dieseljunkie
    Dieseljunkie Light Load Member
    66
    Thanks Received:
    11
    Mar 23, 2011
    Gladstone, OR
    Are you meaning to say that when your time is up the engine shuts itself Dow? The company really does that? Or are you talking just a normal engine idle timer? What kind of motor?
  11. THBatMan8
    1,478
    Thanks Received:
    459
    Feb 13, 2011
    Wherever I park
    Turn on the cruise control. It will raise the RPM's by 100 so the truck won't shut itself off.
    :biggrin_2552:
  • Draft saved Draft deleted
