Hi everyone! Does anybody know how to add gear lube in manual transmission? I've got Volvo 670.
thank you )
How to add gear lube in manual transmission?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Slim one, Aug 3, 2015.
Straight 50w synthetic is what it will likely take not gear lube. Check with the dealer. Should be a plug on the side of the trans that looks like the drain plug. 1/2" drive will fit in it.
Usually the shops use a hand pump that a hose with a small end that sort of hooks into the port of the tyranny. The pump is designed to fit onto a five gallon pail. -
Please don't take this wrong............but if you don't know how to add it............how do you even know it's low?? -
I just want to know where is that plug located to add some lube in transmission. I saw special gear lube containers in truck stop on sale. It is designed to add lube in transmission without using any tools.
Just a side note. Most manual transmissions like 13sp Eton will use synthetic transmission 50w fluid. Not gear oil.
75w-80. Transmission fluid for volvoSlim one Thanks this. -
I would definitely call the dealer with my VIN # to find out exactly what type of oil goes in there if I was OP.
peterbilt_2005 and Slim one Thank this. -
my super 10 by eaton is a 15/16 size square plug, can use crescent too. I use the pump off of the 5 gal but in day's past used a long 1" hose with a funnel at top & poured in ever so slightly as to not waste much running over. my wt was & is 50 wt. not sure any any other type or year. would put finger in hole & if fluid was present, it's good. if not add.
Pull in lube bay at Speedco and tell them to top it off.
Should never need oil unless it is leaking.
