i have a 2011 670 and having a issue with my wipers. they work fine on full or fast but the intermittent craps out a lot. they will work fine for for a while and then suddenly stop working then suddenly start working again. they may not work for 5 min or may not work for 5 days. i was told by a dealer it was the switch on the steering column so i bought a new one and worked fine for a few days and they quit again. check the fuse its fine and swapped around the relay and still nothing. any ideas?
intermittent windshield wiper problems
Discussion in 'Volvo Forum' started by NathanMullin, Nov 17, 2015.
check all of the pins in the green connector that you plugged into the new wiper switch. one or more may be loose. tug on each wire.
not the wiring. took the bottom plastic cover off to get at the wires and had to wait a while for them to quit. they finally did and i checked all the wires unplugged the switch, plugged it back in and no luck. BUT i did have my orig switch in the truck so i unplugged the new switch and plugged in the old one and they worked again. so i unplugged the old switch and plugged the new one back in and the ^%$#& things worked again. kinda leads me to believe the switch itself is freezing up and unplugging them for a short time unfreezes it.
Could be the motor as well. I have to replace my motor every year. Once it starts doing funky things like your having that's when I replace mine then problem solved for another year. Tens mins and $60 right
ouh no, man
Slow is controlled by relay, also used for int mode. SO chack wiper relay! and it wiring
for fast mode other wire is used/
Do wiper park well? -
may be worn contacts inside motor((((
