kenworth fuse panel disassembley
Discussion in 'Kenworth Forum' started by chopperdan, Aug 2, 2012.
  1. chopperdan
    chopperdan Bobtail Member
    Thanks Received:
    Aug 2, 2012
    Anyone know how to access the wiring on a kenworth fuse panel. I need to get in there to fix some wiring and am not sure if it comes apart from the inside or the firewall
  2. TRASHAULER
    TRASHAULER Bobtail Member
    Thanks Received:
    May 19, 2009
  3. chopperdan
    Thanks Received:
    Aug 2, 2012
    It is a 91 but i got it taken care of. Thank you
  4. droy
    droy Heavy Load Member
    825
    Thanks Received:
    149
    Jun 11, 2008
    Iowa, LA
    Sort of related issue, wondering why the heater/ac fans blow with ignition in accessory position? Is it possible to wire it so voltage only when key is "on"?
    Doesn't sound like much of an issue, but when loading/unloading, engines have to be turned off; in some plants, we can remain in our trucks, and listen to the radio. I always remember that I turned the sleeper fan off AFTER I am back on the road.
    (2007 T800)
  • Draft saved Draft deleted
