Hello,
Im a company driver and i drive a 09 mack CXU613, while at work today it asked to do a MANUAL REGEN, so i parked the truck and hit the button, but it didnt work, tried turning off the truck and all and still didnt work, now idk if its just a sensor or something more serious like cleaning the filter or something !?!?
Did anyone already had this issue before ?!?
Thanks !!
Manual DPF not working
Discussion in 'Mack Forum' started by KRAZZYbr, Feb 18, 2016.
Some engines require you to hold the regen button for 4-5 seconds.
KRAZZYbr Thanks this. -
DEF or non-DEF? Had this happen a few times with my '07 non-DEF, usually I would keep driving it, sometimes mine would take 4 or 5 times of this warning before it would finally regen. On a few occasions my boss would have to hook up the laptop and do a forced regen.
May need diagnostic software to "force" regen it.. And it does have to be hot enough to even begin (150-180f maybe)
That's about all I know...KRAZZYbr Thanks this. -
Thanks for the reply !!
Its a non DEF, It went away the next morning then it came back again in the afternoon, they bought the truck recently and it has about 470k miles, asked them if they knew if DPF was ever cleaned and they found out it wasnt, after 3 days of driving without doing the REGEN, light started blinking asking to do a URGENT REGEN, and i knew i couldnt be driving that truck anylonger. Took to a shop the next morning, DPF and DOC needs to be clean, it might need a new Dosing injector because i notice diesel coming out of the top and it has a hole on the exhaust pipe before the DPF, which i told them 2 months ago.
