Manual Vs. Autoshift Transmission
Discussion in 'Experienced Truckers' Advice' started by drivenmecrazy, Nov 27, 2008.
  1. drivenmecrazy
    drivenmecrazy Light Load Member
    54
    9
    Dec 5, 2007
    Oregon
    10 speed auto, which I hate. 3.70 rears, How do you think my mileage will compare to 10 or 13 manual?
  3. YukonTrucker
    YukonTrucker Light Load Member
    203
    51
    Dec 9, 2007
    Whitehorse Yukon
    You will always get better mileage in a manual due to less resistance through the transmission as well as you being able to keep the engine in its best operating zone easier.
    drivenmecrazy Thanks this.
  4. someguy01
    someguy01 Bobtail Member
    8
    Somewhere
    "less resistance through the transmission" ?
    Isn't the autoshift just a regular 10 speed with a robot shifting it ? The transmission drag would then be the same.
    Thanks
  5. Waterloo
    Waterloo Medium Load Member
    533
    158
    Nov 16, 2008
    Grass Lake, MI
    3:70 gears? What motor, truck, what year and what are you hauling?
    Mike
  6. Sportster2000
    Sportster2000 Road Train Member
    1,480
    885
    Jan 5, 2008
    Indiana
    Yes this is true, except the shifting is done by computer control electronic soleniods. The autoshift has a clutch pedal and the ultrashift is a centrifugal clutch (no pedal).
  7. RYITO1122334455
    RYITO1122334455 Light Load Member
    53
    8
    Apr 4, 2008
    youngstown ohio
    the auto's rind up them rpm's and go through every gear all the time.,,so a manual would prolly be better on gas
  8. crazyray
    crazyray Bobtail Member
    43
    4
    Oct 27, 2007
    arcadia LA
    auto's will skip gears just like a manual driver, depending on load also you can manually shift them also, the autos are the future because of better mileage for most drivers and a big reduction in maintinance cost. at least for the big companies, the only real negative is a higher intial cost
  9. dwmac71
    dwmac71 Light Load Member
    183
    92
    Mar 23, 2008
    Lane,ks
    I have an auto shift that I have to run manually after every restart to retrain the computer to get the shift points set right. If i don't it will run the engine up to 2100 rpm before shifting and shock load the drive line and my back
  10. Rodeo_Joe
    Rodeo_Joe Light Load Member
    181
    17
    Oct 24, 2008
    Blackstock, Ontario
    the autoshift is the same as a manual. i'm tryin to convince our boss to conver back to manual.....mechanic said very easy just bolt it up..
    but the question asked 10spd auto
  11. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    being that I am always trucking from and to the UP of Michigan, I will stick with the 10 Manual. I can control it better in the snow.
