Maximum safe cargo weight for u-haul 26' truck?
Discussion in 'Trucking Industry Regulations' started by kdkrone, Jun 7, 2010.
  1. kdkrone
    kdkrone Bobtail Member
    Thanks Received:
    Jun 7, 2010
    I am not sure where, or if I can, post a question like this. I am trying to find out what the actual safe load could be for this size truck, as we have to move a large wine cellar (about 10,000 pounds) 200 miles. If the frame and tires can handle it, that would be great, but otherwise we will have to arrange for a second truck. The empty weight of the truck is 11,500 and the stated capacity on the website is 7600#.
    Does anyone know the answer?
    Thanks
    Ken K
  2. jeepskate99
    jeepskate99 Road Train Member
    1,200
    Thanks Received:
    320
    Nov 20, 2008
    The Great White Northeast.
    Eek. I wouldn't exceed the weight they have listed. It's hard to tell what's "safe" without knowing the exact truck. Sure, the frame and tires can take it. However, can the brakes? Will you be able to stop that truck quickly if you need to? Will you be able to control it on hills? I wouldn't chance it.
  3. Jimbo60
    Jimbo60 Medium Load Member
    518
    Thanks Received:
    430
    Nov 25, 2009
    High desert CA
    Ken...... there's your answer. The safe capacity is what the truck is rated for.
    Sure it may actually be more but...... not a good idea to exceed the rating.
    ........ Jim
  4. Allow Me.
    7,948
    Thanks Received:
    5,106
    May 28, 2009
    Hickman, Ky.
    Yeah, plus they have vacuum brakes only, not air. Get 2 trucks and load forward only, keep the weight from past the back axle to a minimum.
  5. kdkrone
    Thanks Received:
    Jun 7, 2010
    Good point about the brakes! I had only been thinking about tires and frame. I will do the rest of the load in a trailer with brakes or in a second truck.
    Thanks guys.
    Ken K
    jtrnr1951 and Jimbo60 Thank this.
  6. jtrnr1951
    jtrnr1951 Road Train Member
    3,462
    Thanks Received:
    1,215
    Jul 20, 2009
    Standing in the corner, timed out
    Thanks for being safe !!!!!!!
    Jimbo60 Thanks this.
  7. Add a truck driving job review
  8. FreedomFirst
    FreedomFirst Bobtail Member
    22
    Thanks Received:
    9
    Jul 13, 2009
    Bath,PA
    Gross Vehicle Weight Rating: Gross Combination Weight Rating
    350. (a) "Gross vehicle weight rating" (GVWR) means the weight specified by the manufacturer as the loaded weight of a single vehicle.
    (b) Gross combination weight rating (GCWR) means the weight specified by the manufacturer as the loaded weight of a combination or articulated vehicle. In the absence of a weight specified by the manufacturer, GCWR shall be determined by adding the GVWR of the power unit and the total unladen weight of the towed units and any load thereon.
    So if you know the (GVWR) subtract the empty weight from it . This puts you in the ballpark if the truck is licensed to haul it.
  9. phroziac
    phroziac Road Train Member
    3,138
    Thanks Received:
    483
    Jun 16, 2009
    Gary, IN
    Actually its not a matter of licensing. Its a matter of weight rating.
    Licensing is dealt with by the state. The rating is the rating. The licensed weight can be found on the registration..and is probably higher than the GVWR from the manufacturer.
    Most states do not require a uhaul to go to a weigh station. In those states, the cops wouldn't care even if the bumper is dragging on the ground... States with weigh stations that say "all trucks enter", they have to enter. I dont remember which one but one state requires all rental cars to stop too. But states that say commercial vehicles enter, ....nope. Not if its just your personal belongings inside. Trucks over X tons? Depends on what you weigh.
    Go to michigan. You'll find a LOT of semi tractors way beyond the combination weight rating from the manufacturer...since the weight limit in michigan is 160,000......
    It wont be long before someone comes on here saying that he needs an MC# and DOT# and a class B to drive a uhaul.
  10. phroziac
    3,138
    Thanks Received:
    483
    Jun 16, 2009
    Gary, IN
    Honestly, thats something that works PERFECTLY when you're moving your personal belongings...tvs and motorcycles in front, mattresses behind the axle... :D
    Vacuum brakes? Are you talking about hydraulic brakes with a vacuum brake booster like a car? Cause i thought uhauls had regular car brakes...
  11. Allow Me.
    7,948
    Thanks Received:
    5,106
    May 28, 2009
    Hickman, Ky.
    Yeah, they do have "regular car brakes". I call them Vacuum, but I suppose hydraulic is correct. U-hauls are rated under 26001 lbs, which keeps them out of the CMV category. Ca. for instance, say all rental trucks must stop at scales.
  • Draft saved Draft deleted
