MID 128 SID 211 5 Volt DC Supply
Discussion in 'Volvo Forum' started by xiipercent, Jan 7, 2012.
  1. xiipercent
    xiipercent Medium Load Member
    419
    Thanks Received:
    106
    Mar 19, 2007
    Fun w/volvo's.
    I'm excited to figure this one out.
    FMI 4
    symptoms include : poor driveability, strange information displayed on cluster
    ??? poor driveability from a 5 volt dc supply?
    This weekends other exciting maintenance include replacing abs sensor and bracket on Right Front brakes, a new headlight assembly for driver side(mine has the clarity of a clam shell) and a rear of cab light bulb....yehaaa
  2. Pablo-UA
    Pablo-UA Road Train Member
    7,473
    Thanks Received:
    1,427
    Oct 11, 2010
    Borispol, Ukraine
    any sensor ore sensor wiring short and low sensor power supply
    disconnect all sensors one by one to find faulty one.
    Start with oil pressure sensor, crankcase pres. sensor, fuel pressure sensor.
    Inspect wiring
  3. xiipercent
    419
    Thanks Received:
    106
    Mar 19, 2007
    pablo,
    thank you.
    where's your tip jar...paypal?
  4. Pablo-UA
    7,473
    Thanks Received:
    1,427
    Oct 11, 2010
    Borispol, Ukraine
    I have no pay pal
    btw, have you solved your problem?
  5. xiipercent
    419
    Thanks Received:
    106
    Mar 19, 2007
    no- it must be related to my 'oil can' dash monitor, which still reads zero.
    I can't figure out how the sensor cord attaches.it wiggles in both directions; clock-counter clock.
    i'm sensitive to apply to much 'hand torgue' to the snaplock??
    same for the crankcase sensoe that was replaced last month.
  6. Pablo-UA
    7,473
    Thanks Received:
    1,427
    Oct 11, 2010
    Borispol, Ukraine
    what engine? D12D ore D13?
  7. Add a truck driving job review
  8. xiipercent
    419
    Thanks Received:
    106
    Mar 19, 2007
    2006 vnl 780 d12 6n434786:biggrin_25514:
  9. sbaumann14
    sbaumann14 Medium Load Member
    312
    Thanks Received:
    163
    Sep 1, 2010
    Rhinelander, WI
    I'd start with the crank sensor that was just replaced...might not have tightenedit all the way
  10. Pablo-UA
    7,473
    Thanks Received:
    1,427
    Oct 11, 2010
    Borispol, Ukraine
    it is D12D. The last D12 in Volvo... Some D12F were in Renault but in F version with ECM like on D13.
    Ok, where to find problem.... really everywhere. Dealers use brake boxes to find bad sensor ore bad wirng. I use the other way - separate ECM connector and check all sensors one by one, I have wiring diagram of D12D EU and US versions, so I can post it to you. Simple DVOM really helps
  11. xiipercent
    419
    Thanks Received:
    106
    Mar 19, 2007
    so.
    Volvo dealer is saying that the 5volt was traced to the egr#2.
    my response- If you replace the egr#2 , will it solve the "zero" reading on my oil pressure dash gauge? (because they say it operates off the same circuit.)
    If I'm not throwing any fault codes for EGR, why would replacing the unit solve the 'short' problem. should'nt they instead look for the 'short' problem?
  • Draft saved Draft deleted
