N14 water pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mr. Truck Fixer, Oct 25, 2012.
  1. Mr. Truck Fixer
    Mr. Truck Fixer Bobtail Member
    44
    Thanks Received:
    12
    Jan 27, 2012
    Ontario
    Wondering if anyone has ever had repeat water pump failure on n14. The original one lasted 7 years now I changed three in six months. What gives? Another truck in the fleet has had 6 pumps is twelve years. Getting tired of changing water pumps. Dca levels are always good and good quality coolant.
  2. losttrucker
    losttrucker Road Train Member
    1,438
    Thanks Received:
    1,017
    Mar 9, 2008
    greenville,nc
    In my opinon its the supplier using cheap rebuild kits as I had the same problem with my Detroit!! Example, the backing plate on the original was metal while on the rebuilt ones (all 3) have had cheap flimsy plastic that seem to start leaking immediately!!
  3. Mr. Truck Fixer
    44
    Thanks Received:
    12
    Jan 27, 2012
    Ontario
    Always replaced with reman cummins parts. Flushed and new rad cap everytime.
  4. Smellfunny
    Smellfunny Medium Load Member
    671
    Thanks Received:
    205
    Jan 28, 2012
    South Carolina
    We had an N-14 that we put 2 on back to back. They were aftermarket (Haldex).
  5. blanco
    blanco Road Train Member
    1,220
    Thanks Received:
    279
    Nov 20, 2009
    Gwinnett County, GA
    I'm ready to do mine sometime soon. I've had replaced it 5 yrs ago. Cummins reman. It is the only one I will use.
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    Thanks Received:
    631
    Feb 21, 2010
    Rock Creek B.C. Canada
    Haldex is a Cummins division, and if you are using DCA4 that does not help at all it is 100% crap, if you do not change the filter it will wear out the seal easily, the belt it needs to be adjusted properly. I always used OEM reman, and never use DCA4, The rust you see when you have the pump off is nothing compared to the damage to the liners.
  • Draft saved Draft deleted
