No issues actually running on the road with freight. Just usual paperwork, permit book issues.
French is spoken mostly in Northern Ontario, Quebec and the eastern provinces. I don't speak it, but never had a problem getting things figured out as long as you have a pleasant attitude.
If you are running super single tires at USA weights you can get around fine. At Canadian weights you can't go into some provinces with them fully loaded.
Need help with research project; Canadian vs US trucking
Discussion in 'Canadian Truckers Forum' started by dmlejeune, Apr 17, 2016.
Page 2 of 2
I would think biggest issue province to province would be axle weights and spacings but i would also suppose thats same state to state. Here in Ontario you need a CVOR which i guess is kinda like a DOT#? It is your running authority to operate in Ontario. I believe Quebec has similar...not sure of other provinces?
dmlejeune Thanks this. -
quebec has spring thaw weight reductions on their major highways
almost every other province its only on the secondary highways -
Am I the only one that sees an issue here? Seems rather trolling like. Doesn't seem very well informed for claiming to have the best trucking software in the business..
Prairie Boy Thanks this. -
Don't get into trucking. Forget the software and get one on to flip perfect burgers.
Page 2 of 2
