Oil cooler c15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by loudhornsrule, Feb 15, 2009.
  1. loudhornsrule
    loudhornsrule Light Load Member
    74
    Thanks Received:
    40
    Jan 29, 2009
    north texas
    How hard is it to change the oil cooler on a c15 6nz motor? Any special tricks ?
  2. Bigstretch
    Bigstretch Light Load Member
    161
    Thanks Received:
    27
    Jun 14, 2008
    NW IL
    Was pretty easy to do on my W9. Wide open access. :D
    Drain the cooling system.
    Remove the bolts for parts that are on both ends of the cooler. There is 1 huge fat o-ring for each, where they attach to the oil cooler.
    The cooler its self has 2 bolts on the bottom (Both bolts are facing up. have to feel around to find them.) that attach it to the oil filter base. There are 2 large o-rings there.
    The re-man cooler should come with all of the o-rings, and get I'd also replace the rubber coated gaskets. Cheap insurance. Make sure they get you the correct ones. There are a few different ones there could be. Just take the old ones with you and match them up.
    Reassembling the pieces that go into each end of the cooler and flushing the cooling system is the biggest PITA. The rest goes pretty easy. Make sure to lube up all of the o-rings to aid assembly, and to prevent tearing an o-ring.
  3. 05chopper
    05chopper Light Load Member
    169
    Thanks Received:
    17
    Dec 25, 2008
    USA
    I take it you know for sure its the oil cooler leaking or you just feel you need to change it?
  4. DDS
    DDS Medium Load Member
    510
    Thanks Received:
    153
    May 20, 2008
    Toronto
    I have found any oil cooler that has more than 700 000 miles should be changed. It is easier to change before failure due to oi in the coolant can be hard to flush. When the oil cooler gets older the rubber starts to come apart, I have seen three engines last year with siezed pistion pack from a piece of rubber from the oil cooler core plug a cooling jet. I always replaced the cooler during a overhaul to prevent this type of failure.
  5. 05chopper
    169
    Thanks Received:
    17
    Dec 25, 2008
    USA
    Yea I have seen this too even saw silicone in the oiler from someone who doesn't know better.
  6. Loaderlou
    Loaderlou Light Load Member
    108
    Thanks Received:
    36
    Feb 24, 2014
    Could anybody give me an opinion of a PAI oil cooler for my C15 6NZ
  • Draft saved Draft deleted
