Trying very hard to remove a broken dipstick tube- Any advice WITHOUT dropping the pan?
I applied Heat-then PB-Yanked on it till my shoulder popped out- Will Not Budge
Thanks.
Oil dipstick tube removal C-12
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stayinback, Oct 28, 2016.
push it in... its got nowhere to go but stay in there in till you pull the pan later when it starts leaking or it might come out the drain if its small enough
maybe try putting a screw in it, and pry on the screw with a plier or barstayinback Thanks this. -
Tried the Vise-Grips at the Base......Hit it with a 5 pound sledge- STILL WONT BUDGE-
This has got me- If I drop the Pan- Every Cuss word Is flying out- So don't anyone come around
