So got a 1985 359. A/C was working for the summer then just stopped. Compressor is good, can jump it to engage. High and low sensors have voltage at both sides. Fan switch power both sides. The only thing is the relay is kind of screwy. No Relay 30 85 and 86 has 12volts. 87 ground. Relay same thing 30 85 and 86 have 12 volts and 87 ground. Soon as I grond 85 or wire 570 according to the diagram. Get power to the compressor. My question is how do the high low sensor ground. Is that controlled by the ECM, do the ground through the tubing. Or is there a short some where cause I havent found anything rubbed through yet. Any help would be greatly appreciated
Peterbilt 359 A/C not working, beyond stumped
Discussion in 'Peterbilt Forum' started by ThatGuy88, Aug 16, 2016.
A 1985 would not have an ECM. Sounds like the first thing to check would be to see if you have any refrigerant charge in the system. The compressor only works if the system pressure is within a certain range. With no or low refrigerant, the low pressure switch will prevent the compressor from engaging because there isn't enough static pressure in the system (properly charged system typically has about 70psi static pressure at room temperature. Its not a 100% accurate way of knowing if its properly charged but it tells you there is at least something in there).
I just re-read your post a few times. 86 should be control power, 85 control ground, 30 should be fused power and 87 should be your normally open. Basically once you switch on your circuit, 12 volt control signal should be available at 86, which grounds through 85. That circuit actuates the relay, which should send 12 volt power from 30 to 87. In most cases, pin 30 should have constant 12 volts with key on. Pin 86 should only have 12 volt power with the accessory switched on. Pin 85 should be grounded, and pin 87 should be wired directly to your accessory. I would look into why you're seeing 12 volts on the ground side of your relay control circuit as well. Without a schematic available its kind of hard to try and diagnose electrical over the internet lol.
Sorry wrong info this ones a 2000
Thats what had me confused as hell becuase it was getting power from both sides of the control of the relay. So it wouldn't energize opening up the switch for 87 to power the compressor. Been checking for a short but second I unplug the harness at the firewall nothing. No power on either side which is also confusing. The motor is a celect cumapart and I have been pulling my hair or would if I still had hair on this for 2 days now.
3lbs of 134a as recommended too, no leaks
I'd check to see if your getting power from your hvac on/off toggle to the A/C thermostat switch, then chase wire from there to your trinary switch on the dryer.
