Power inverter
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Cw5110, Oct 21, 2016.
What he said. I run a 2000 watt unit I picked up at a Harbor Freight for like 190$. It's a modified sine model. I wouldn't recommend you go that cheaply as I am now looking to replace after 6 months due to very loud, (annoying), fan motor. It runs a small dorm room type fridge and 1100 watt microwave just fine. I also have a ceramic top portable cook top that it will not power. Have to turn on apu with 110 outlet to power that thing. A true sine wave would do that just fine as it is comparable to household power. The wife and I cook a lot on this truck so new unit will be coming sooner than later. Only drawback to pure sine wave is cost, 2-3 times that of modified, and like anything else, the better brands are pricier.
IndianaF150 Thanks this. -
2-3 times cost that is.
Will be looking at R/V store for new unit.
I have purchased a few inverters from this company.
all have been working perfect and still going strong over a year later. have recomended them to others, all reporting good product and no problems.
theinverterstoreIndianaF150 and Cw5110 Thank this. -
I've only used small cig plug inverters for puter.
Is it safe and reliable using a bigger one for a small fridge, leaving it on all the time? What's it do to the batteries?
How long can they run with truck motor turned off? Any info helpful. I want a slightly larger mini fridge than the ones designed for trucks. Maybe 3 ft fridge -
Yes, you can find many power inverter brands when googling. But don't just look for something that is cheap. Cheap ivnerters can't guarantee high quality and high safety. Damages are easy to occur when using a power inverter without full protections. I always use Bestek power inverter which is also the top googling inverter brand. I'm now using Bestek 300w power inverter, but you can find many other models from Bestek. But you need also to use inverters in a right way. Don't make your device overloaded.
