Power steering start making noise when you turn. Will try to change filter. Also truck is not stable on the road. To much play in power steering. Is any adjustment to eliminate play?
Power steering noise.
Discussion in 'Volvo Forum' started by Snailexpress, Feb 3, 2016.
Page 1 of 3
Hi Snail, I've never seen a filter on the PS. Maybe the newer trucks. Sounds like the steering box is worn. Adjusting the free play never worked for me. ( just bound up the box)
If poss. if you can change p/s filter jack up both ft. wheels and turn steering wheel slowly all the way back and forth listening to steering box for changes in sounds from pump, the valves inside steering box can wear and make sounds like you are hearing?
201 Thanks this.
Snailexpress Thanks this.
Wow it is scary. It feeling like 1/2 turn with some resistant then like on ice
KB3MMX Thanks this. -
KB3MMX and Snailexpress Thank this.
The is a bolt at Pitman (?) arm when it connects to output shafts . They will get loose, and make truck wander .
Snailexpress and KB3MMX Thank this. -
Any resolution on this? My steering is humming and the #### truck is all over the place. Alignment good. New king pins new tierods. New bearings. New PS filter. Steering groans at slow speed and truck wanders and is slopping.
KB3MMX Thanks this.
Page 1 of 3
