Hello my name is mike i own 2009 termo king sb210
I set my reffer -10 loaded with froozen product on hot sunny day 100F
and my reffer only goes to 16 in arizona
please help does it has to get to -10 no metter what or and how long it takes thanks
Problem with temp takes long
Discussion in 'Refrigerated Trucking Forum' started by MIke1994dk, Jul 6, 2015.
100 degrees is hot! Heat coming off the asphalt! Hot!!
However, yes. It should still cool down to set temperature, or very close to it. If you precooled your trailer before loading, there shouldn't be that much of a problem. My guess is there is a problem with your reefer. Probably low on refrigerate. -
Tall Mike Thanks this. -
SB210 units are barely enough when unit and trailer were new after awhile the wall insulation in trailer loses some of its efficiency and unit struggles to keep up in high heat .. Whatever fuel savings that were had can be lost in one shot if a big claim happens .. Swing by thermoking and get it checked out but it's possible that it's trying to overcome to many conditions it wasn't designed for
