can anyone help with trusted shop to service detroit in 2005 century
we did overhaul probably 200k ago at dealer and since then never had any single problem with engine , recently changed the manifold due to the crack .
today in the morning driver started experiencing lack of power , hiccups (clogged fuel filter symptoms)
when he goes on the road truck does not speed up more that 30mph and idling rough trying to shut down
problems with detroit , houston area
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pavrom, Oct 26, 2016.
Did you change fuel filters. If so make,sure the O rings are ok and thr spin nut to clamp the bowl didn't get crossed threaded
filter been changed in chicago last week ... this is 1st thing we checked .... i am thinking about injector ....or it sucking air somewhere
Does it start hard. Before starting . look and see if there is fuel in the plastic bowl. If not then someone goofed putting on new fuel filter. Trust me, I've had it happen no fuel means an air vent in the system. Also look and see when running if air bubbles in the fuel. If that then the check vavle is bad in the fuel filter body
it starts hard .... i thought about check valve again (replaced check valve last winter)
no plastic bowl on this truck
mechanic showed up and pointed hole in the fuel line ... i hope thats the reason -
Fuel pump O ring. If it is taking in air, you aint gonna get power.
Intercooler line clamps to turbo. If you caved in a clamp the overall air to engine sucks. (Pardon the pun...) -
truck was running perfect just yesterday -
Somewhere somehow you will find the real problem.
Engines need fire to run, fuel to get it. Air to breathe to burn and compression to light it. -
What are the RPMs like? Can you throttle the RPMs higher than about 850? I'm assuming during the rebuild the valve lash got adjusted...or when was the last time the valves were adjusted?
Seized injector, broken tip, cracked injector bodies.
Are you getting excessive black or white smoke? Maybe you're getting excessive aeration in the fuel?
