Prostar auto headlight switch?
Discussion in 'International Forum' started by My11Inter, Apr 16, 2016.
  1. My11Inter
    My11Inter Bobtail Member
    41
    May 19, 2015
    Having problems with the auto headlight switch. It's the switch that's next to the work (utility light switch). The switch green indicator light keeps turning on and off on its own, and makes the headlights run on and off while driving. Could it be the switch itself, or electrical short? Is this controlled by the body controller? Thanks!
  3. Heavyd
    Heavyd Road Train Member
    7,625
    6,023
    Feb 4, 2009
    I would say it is a problem with the switch.
    My11Inter Thanks this.
  4. tucker
    tucker Road Train Member
    12,647
    40,420
    Jun 13, 2008
    IN
    Or it might not be the switch as using the wipers turns on the lights without pressing the switch.
  5. My11Inter
    41
    May 19, 2015
    Thank you sir. Will call dealer to order switch and see if that's the problem. I know it's normal on these trucks for the lights to turn on with the wipers. Right now, not even with wipers turns the lights on. Just work on their own all of a sudden while driving.
  6. My11Inter
    41
    May 19, 2015
    Called the dealer for the switch, and man, almost $300. I'll just live with that faulty switch for a while going on and off. Thanks again.
  7. Heavyd
    7,625
    6,023
    Feb 4, 2009
    You can have that programmed out too. Next time you are in, buy the guy a coffee and he will probably do it for free.
    2013Maxx Thanks this.
  8. My11Inter
    41
    May 19, 2015
    I'll try that one. ;)
  9. 2013Maxx
    2013Maxx Light Load Member
    133
    41
    Jan 17, 2018
    Any update on this? Mines started doing this today!
  10. CoolHand244
    CoolHand244 Bobtail Member
    6
    Having a problem myself, truck is a 2010. While the truck is parked in the parking lot, the lights just start flashing by themselves and in no particular order.
  11. Heavyd
    7,625
    6,023
    Feb 4, 2009
    Press and hold the headlight switch in the on position to see if this cures the problem. If it does, then the rocker switch is not making contact with the micro buttons on the circuit board inside the cluster.
