PTO/Blower for pneumatic trailer/sand hauling
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stinerspecialtransport, Aug 19, 2011.
  1. stinerspecialtransport
    stinerspecialtransport Bobtail Member
    31
    Thanks Received:
    4
    Aug 18, 2011
    Midland, TX
    I have recently lease our 98 pete 379 to a company hauling frac sand. They require a PTO and blower to load and unload the sand on well site location. They are going to charge us $9000 for the parts and installation. Just wondering if there is a less expensive way to do this this and what type PTO and Blower would be required. Any direction you guys can give will be greatly appreciated.
    Thanks,
    kee1227 Thanks this.
  2. Pablo-UA
    Pablo-UA Road Train Member
    7,483
    Thanks Received:
    1,428
    Oct 11, 2010
    Borispol, Ukraine
    the less expencive way is to purchase pump, fluid tank and other stuff used ore on wreked yard and do all installationg yourself.
    stinerspecialtransport Thanks this.
  3. 98989
    98989 Road Train Member
    2,253
    Thanks Received:
    443
    Sep 14, 2008
    Zagreb,Croatia,Europe
    can you please explain what kind of trailer you will use
    if i understand you good you need air compressor for unloading? like for transport of cement or anything similar?
    why?
    i have never heard for that
  4. stinerspecialtransport
    31
    Thanks Received:
    4
    Aug 18, 2011
    Midland, TX
    We will be pulling pneumatic trailers which require air pressure to push the sand out of the trailer in order to unload.
  5. power freak
    power freak Light Load Member
    220
    Thanks Received:
    50
    Apr 23, 2009
    I run a fleet of 35 trucks with positive displacement blowers to run pneumatic tanks, I run either a drum d807 or a tuthill t850 powered by a Chelsea PTO. You will want to get as close to a 200% ratio as u can to keep to engine Rpms close to 1000 while unloading. For a new install with a steel muffler and air cleaner you will have between 6 to 7 grand in parts. I have quite a few trucks hauling sand and it takes more air to unload than cement so don't try and cheap out and go with a smaller blower than what I stated or unload times will increase.
  6. Raiderfanatic
    Raiderfanatic Heavy Load Member
    809
    Thanks Received:
    551
    Jul 18, 2010
    Hutchinson, KS
    We were told it would cost 7000 bucks to move our PTO and blower etc from one truck to another. Personally, I found that to be outrageous but maybe there's alot more to it than I realize?
  7. power freak
    220
    Thanks Received:
    50
    Apr 23, 2009
    7000 that is outrageous we install a complete system in our shop in about 16 to 20 hr's depending on the chassis. So even at 100 dollars a hour and 5 hr's to remove the old system labor should not be over 2500 dollars. Even if they rebuilt the blower and the pto 7000 still seems steep
  8. stinerspecialtransport
    31
    Thanks Received:
    4
    Aug 18, 2011
    Midland, TX
    I don't currently have a PTO or blower on my tractor. So, it's $9000 for the equipment and the installation. That sound fair to you guys?
    Thanks for all your help guys.
    Toby
  9. 98989
    2,253
    Thanks Received:
    443
    Sep 14, 2008
    can you please post picture of that trailer you will pull or picture how it is unloaded or maybe describe why you have to use compresor at all
    i have never heard that somebody use anything except tipper trailer for pulling sand
  10. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,973
    Thanks Received:
    1,540
    May 13, 2011
    SW Missouri
    This is sand for oilfield use and it doesn't get dumped, it gets blown off like flour. Maybe someone who actually has done this will give better details.
  • Draft saved Draft deleted
