Rear suspension won't dump
Discussion in 'Volvo Forum' started by Nunez770, Sep 15, 2016.
  1. Nunez770
    Nunez770 Bobtail Member
    9
    Aug 23, 2016
    I have a brand new leveling valve and brand new dump switch and my suspensions won't dump. Any suggestion?
  3. flood
    flood Road Train Member
    4,023
    3,758
    Dec 25, 2010
    check the wiring at the switch.... needs to have power when the key is ON
  4. nasriza
    nasriza Road Train Member
    2,368
    2,040
    Feb 1, 2013
    Chicago, IL
    Check your solenoid under the chassis probably burned out that's y it's not dumping volvo runs electrical solenoids with switches to dump suspension and lock diffs also for fans and air horns usually located right behind transmission depends on the year of the the truck
  5. Nunez770
    9
    Aug 23, 2016
    I have a 2006 vnl770. Would that have to do anything with my fifth wheel not moving either?
  6. boneebone
    boneebone Road Train Member
    2,232
    2,266
    Mar 13, 2009
    A 2006 is a VNL780 Model, the VNL770 was produced from 1998-2003.
  7. Nunez770
    9
    Aug 23, 2016
  8. nasriza
    2,368
    2,040
    Feb 1, 2013
    Chicago, IL
    Check your fuse Panel For Chassis solinoid fuse it should be 10 amps
  9. Nunez770
    9
    Aug 23, 2016
    Where is that fuse located?
  10. nasriza
    2,368
    2,040
    Feb 1, 2013
    Chicago, IL
    check the bottom of fuse panel cover is should say chassis solenoid i do not know the exact number from top of my head around f50's or f60's row
  11. Nunez770
    9
    Aug 23, 2016
    Ok thanks. By any chance do you happen to have a picture of the solenoid you told me to check. I tried calling the dealer and they telling me Volvo doesn't use one.
