Volvo 770 13 speed with Cummins N14. Driving today and rpm go high without acceleration and then drop down. What can be the problem? I had a shop install a new injector yesterday, but dont know if it can be connected to the problem. The truck ran fine for 300 miles this morning, but then this thing started.
Rpms go high without acceleration
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DUNE-T, Dec 1, 2015.
Page 1 of 3
TPS in the pedal maybe?
Was this on pedal or cruise?
You sure the clutch isn't starting to slip?
See any smoke? -
throttle position sensor
blairandgretchen Thanks this.
If the rpm went up, but the truck did not accelerate, then the clutch was slipping.
If the rpm gauge went up, bit it didn't sound like the engine changed its tune any, then it may just be the crankshaft sensor.back street slider Thanks this. -
It's called a Accelerator Position Sensor, which could be bad and/ or the Accelerator Pedal itself, which with use and age starts getting worn and gets play in it, so the Sensor doesn't read that it has returned to the 0 position. That's why there is a delay in your throttle response.
If you buy a new Pedal the APS (Accelerator Position Sensor is included too.
Page 1 of 3
