Running coax in a cascadia
Discussion in 'Freightliner Forum' started by dogchimp, Aug 3, 2013.
  1. dogchimp
    dogchimp Medium Load Member
    674
    Thanks Received:
    185
    Jan 31, 2013
    Does any one know if the over head cubby on the drivers side comes out? I was trying to run coax behind it for my cb, and can't get the cable back out, or past where I need it to go
  2. jbourque
    jbourque Heavy Load Member
    924
    Thanks Received:
    535
    Oct 25, 2012
    south english iowa
    i did it the easy way just gave up. you think freightliner would make it easy to do but oh no we cant have that. the problem with there cb coax is it all comes together at a junction box and the tv ,cb,and fm radio are all hooked together. if i remember right the d/s antenna is the only one that is for the cb. lots of luck with that nightmare
  3. dogchimp
    674
    Thanks Received:
    185
    Jan 31, 2013
    after about 4 hours of fighting with it, I clipped the coax that got stuck, and ggot a cable that was a little thinner, got it to run how i needed it now
  • Draft saved Draft deleted
