satellite radio antenna mounting locations on freightliner cascadia
Discussion in 'Trucks [ Eighteen Wheelers ]' started by corneileous, Jan 12, 2010.
  1. corneileous
    corneileous Road Train Member
    1,254
    Thanks Received:
    284
    Nov 19, 2009
    Just wondering where you fellow cascadia drivers have found a suitable mounting location for an xm antenna and still get descent reception. So far, all I've been able to find is either the mirror mount on the top of the passenger door or a place I found on the passenger side of the wiper cowl but either place only has so-so reception when I go south. Do them monster-sized satellite antennas they sell in truckstops work better despite having to be mounted to the highest point of the vehicle like the ones that come with the radio do? I'm using the stock magnetic one now, always have been even on my car and it worked great but that was only cuz it didn't have this ginormous sleeper roof blocking its view from the satellite. I think mine would work way better I'd I could for one, be able to get it up there and two, find a place to mount it to since everywhere I've found is all fiberglass
  2. lovesthedrive
    lovesthedrive The Confuzeled
    5,298
    Thanks Received:
    5,149
    Nov 11, 2008
    Sorrento, Maine
    If you have enough wire, why not mount it to the Qualcom receiver mount on the back of the cab?
  3. jeepskate99
    jeepskate99 Road Train Member
    1,200
    Thanks Received:
    320
    Nov 20, 2008
    The Great White Northeast.
    I put mine on the dash and it works.
  4. corneileous
    1,254
    Thanks Received:
    284
    Nov 19, 2009
    I thought about that but as I mentioned, I don't know how I'm gonna get up there without a ladder and for two, I don't know if the wire is long enough and even if it is, how to get it into the cab simple enough without havin to get all McGyver on it.
    To the person that said their antenna is on the dash;
    You must have a better antenna cuz mine is mounted outside the cab in virtually the same place and if I'm traveling north or west, the display on the radio spends a lot of time displaying the words "no signal". Does that aftermarket antenna I mentioned in my opening post work better regardless of where its mounted?
  5. walleye
    walleye Road Train Member
    3,024
    Thanks Received:
    4,287
    Aug 21, 2007
    Land of Cheese
    Can't you just run it out the passenger door and through it on the roof??
  6. BrainHurtz
    BrainHurtz Light Load Member
    245
    Thanks Received:
    53
    Jun 24, 2008
    Terre Haute, In
    Just like mag mount ham radio and CB antennas the satellite radio antenna works best when mounted on a nice big metal ground plane. Unlike ham and CB antennas though I haven't seen any off the shelf satellite radio antennas designed to work without a ground plane.
    Maybe somebody else has seen one?
  7. Add a truck driving job review
  8. Palazon
    Palazon Road Train Member
    1,431
    Thanks Received:
    898
    Feb 5, 2009
    Tacoma, WA
    I use an after market antenna for $30 at Pilot. Looks like a small baton and mounts to the mirror. Good reception (Pacific NW) everywhere except tight mountains.
  9. striker
    striker Road Train Member
    3,655
    Thanks Received:
    2,086
    Aug 8, 2009
    Denver, Co
    there are a couple of options, are you using just the little mouse like antenna? if so, get some heavy duty double sided sticky tape and put it top of your mirror (use some zip ties to hold the wire to the bracket. Typically the wire is about 25' long so you should have many different options.
    the other thing would be that you can run the wire and antenna up and onto the roof and attach it there with the tape as well
  10. corneileous
    1,254
    Thanks Received:
    284
    Nov 19, 2009
    Well, I think I solved the problem... We were fortunate to grab breakfast this morning at a truckstop and very close by was a Home Depot. Got some stuff, and it worked....
    Bought a 2 foot stick of 5/16 all thread, some nuts and washers, and a "T" steel plate. Bent the long part out 90 degrees, mounted it to the mirror mount just above the passenger window and bolted the all-thread to it and used an extra fish-eye mirror mount bracket to the top that I had rollin around in the tool box to use as a magnetic base . Wrapped the all-thread with some electrical tape so the threads didnt cut into the insulation on the wire, wrapped the wire around the all-thread and routed the wiring into the cab.
    Thanks for all the suggestions, tho....
  11. frago
    frago Light Load Member
    225
    Thanks Received:
    104
    May 26, 2008
    NW Iowa
    Bit of an older post, but I just got a cascadia and ran through these probs trying to get XM reception.
    What I found by accident was a metal plate at a Flying J , and mounts to the CB Antenna at the base via a hole. You screw the antenna through it and it gives a metal plate to mount the little magnet antenna to. I put it on the passenger side and it doesnt receive worth a ####, so I moved it to the drivers side and it works perfect. I get reception is all directions of travel now and even on thick tree lined roads.
    Best of luck to anyone.
    tech10171968 Thanks this.
  • Draft saved Draft deleted
