I have a 2015 t680, and the right side led fender blinker has quit working. When all the lights are switched off, it works. When you switch the lights on, the marker light works, but does not blink. All the rest of the right side blinkers work, and the indicator on the dash blinks about twice as fast as usual. Has anyone else had this problem? What was the fix?
The plug was still connected, and gave no appearance of broken or loose wires.
T680 Fender Blinker
Discussion in 'Kenworth Forum' started by Karl Matthews, Jan 16, 2016.
Have you tried shutting the truck off and restarting it?
Mine does the same thing don't know why
When mine starts blinking fast on the dash there is nothing blinking on the outside. If I turn the turn signal off and then right back on, it works normally.
And it only seems to happen turning left. -
Mine is on the passenger fender.... flashes fast on dash but the rest of the blinkers work
Karl Matthews Thanks this.
CK. the bulb with 12V. just to be sure its still good?
