I've always wanted an old day cab W900A so I went and bought one last year. I'm just curious if anyone has ever registered a tandem class 8 truck for private/pleasure use? If so do you have to run a log book and abide by the hours of service? Are annual inspections required? I do have my Class 1 with air. At this point in time I'm bouncing between BC and AB and I'm not sure where I'll be permanently when I get the truck on the road in the next year or 2.
Tandem truck for pleasure use?
Discussion in 'Canadian Truckers Forum' started by AModelCat, Aug 3, 2015.
Google: HDT (heavy duty truck) RVs. There are lots about and there are forums dedicated to them... lots of tips for navigating the various provincial motor vehicle departments. If the truck is registered as an RV then it is, by definition, not a CMV; therefore no log book, no HOS requirements, etc. It may be subject to an annual inspection if required for such a registered vehicle in your home province. If not actually being used as an RV, at least removing the fifth wheel would go a long way towards claiming non-CMV status.
A number of years ago I bought a Freightliner Classic in the U.S. and drove it back to Calgary on in-transit registrations (personal, not commercial) and personal insurance... no log books, etc. I did roll through a couple scales in the U.S. (easier than explaining after-the-fact), but didn't get pulled in. Didn't roll through any in Canada.AModelCat Thanks this. -
No affiliation and no experience, but by viewing, one of the most experienced in this area appears to be here in Calgary: http://rvhaulers.ca/ At least it's a place to start.
That's pretty neat. I wonder if it's possible to side step HOS and log books by applying for collector plates. There's a guy somewhere in western Canada with a 25th anniversary W900 and I noticed it had collector plates.
I would say as long as it is not used for commercial purposes you don't have all the DOT, CVSA etc. to put up with.
Saw an older Mack in Quebec that a guy had changed to single axel and a dually pick up box.
