Well it is only less than a year old, and already it has a major problem, it just quit receiving GPS signal and it got stuck in Pendleton Oregon on I 84 with one of my previous trips.
I try to reset it and that didn't help
I called rancmcnally and after telling to do this and that and no luck they are telling me to send it to them.
I beleive there may be one of you who had this problem and successeded to fix this problem. Please share with me. How you did it.
Tnd T80 no GPS signal
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Hardworker, Jul 24, 2016.
I doubt its the gps. Wait till tomorrow and see. I have exact same problem couple times a year.
Hardworker Thanks this. -
Tho
Now I'm going to have to start all over........
ETA- Lead paint and seatbelts @TripleSix @passingthru69 -
Hold the power button down for 10 seconds, should fire back up!
Broke Down 69 Thanks this.
Have you tried to directly plug the power into the Tablet and bypass the Slice and see if it picks up GPS? The Slice is a GPS receiver booster and may have gone bad.
The GPS antenna without the Slice is directly on the back of the Tablet. Make sure it is in a vertical position also.
As mentioned. The Government does move the GPS satellites to a higher orbit a few times a year.
Tall trees and building around you may affect your ability to pick up a GPS signal also.
Do you have any Dash Cams or any other electronics you have added recently?
Thanks,
Mark
