I have to admit I actually see his point.
It is true though, the higher you put the load the lower the take-off angle and greater the distance which is why I've often heard drivers talking on Firestik antennas 30 miles away.
This antenna talked 85 miles (mobile to base) with a Stryker radio going into a straight 6 Class C amplifier.
(I'm sure it was a freak occurrance. All the stars were in alignment that day)
top load vs center load antenna
Discussion in 'CB Radio Forum' started by fgb3, Dec 18, 2011.
Page 8 of 17
Reason for edit: angle of radiation -
Because I thought that the guy made a good point
I think he was just talking about the guy saying aircraft antennas are the best ones or something like that
Not a bad compromise between structural integrity and performance. -
Actually if ya look at a 10k,its more of a mid load rather than a top..I played around with a 10k k's top mast and make it 50% shorter with so so results..
bored silly Thanks this. -
Top load 5/8 wave wire wound glass antenna is the answer to the OP's question. The thicker the glass rod the better, as tall as you can run on your truck.
KISS -
Reading comprehension issues? Lack of inferred common sense?
What part of "as tall as you can run on your truck" eludes your thinking?Highwayman1224, slim6596 and rabbiporkchop Thank this.
Page 8 of 17
