I had a 2012 step deck dropped off and when I hooked up to it and pushed the trailer air break in I couldn't get the dump valve to close. There isn't any electrical wires going to it and I don't know how to close it up. Is the problem the truck wiring or a problem with the trailer? Thanks.
Trailer Dump valve won't stop dumping and it has no electric wiring.
Discussion in 'Flatbed Trucking Forum' started by B Sharp, Nov 26, 2015.
Page 1 of 3
How cold is it where you are at. might be froze up
Check for a manual dump valve on the trailer
What position is the leveling arm in? Is it even hooked to the rod?
Unplug pigtail 1st to see if leak stops,Ck. for power on the center wire in your pigtail it may be wired to the dump valve, as some older trailers had center wire used for dump valve? unpl
kylefitzy Thanks this. -
Did I read something wrong? You posted it has no electric wiring??
baha Thanks this.
Page 1 of 3
