On a 2014 cascadia evolution.
I read the manual. It says
It could be low oil l, loss in water temperature, or failed to start. Does anyone know how to fix it. I check the fluids levels and they were good.
Tripak apu ENG fault code
Discussion in 'Ask An Owner Operator' started by naserrano22, Jul 30, 2016.
Did you try resetting it? Sometimes there is a momentary glitch. If code goes away you would be good. On the older tripacs there is a reset button on the side of the box where the circuit board is. The box may be under the bunk. Or in side box depending on installer.
Yeah i tried doing that but after 10 minutes or so it will automatically shut off and the fault code will appear again. It looks like i will have to take it thermo king really was hoping i didnt have to.
If the little precooler fan on the side of the unit isn't working, it will overheat and shut down, even if it's plumbed into the truck's cooling system.
Check the fuse for the fan.
