Truck info for NYC.
Discussion in 'Experienced Truckers' Advice' started by MACK E-6, Aug 14, 2008.
  1. MACK E-6
    46,049
    201,712
    Truckernurse, socal, Woodport and 11 others Thank this.
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I tore that page out of my map. So I can't go there....:biggrin_25523:
  4. MACK E-6
    46,049
    201,712
    Me neither. My truck starts to not run right when I get up thataway.
    NavigatorWife, imouthousejr and cdreid Thank this.
  5. bbkeo
    bbkeo Light Load Member
    281
    19
    Oct 7, 2007
    winston salem nc
    Heck I am up here so much I am thinking of moving here.
    imouthousejr Thanks this.
  6. CornCob
    CornCob Light Load Member
    63
    53
    Aug 8, 2008
    Bayville, NJ
    Just remember all Parkways in NY are off limits to trucks. Despite all the signs & warnings, drivers still mess up. Maybe some of them just can't read English.
    The Hutchinson River Parkway
    The ''Hutch'' is one of the older Parkways in NYC.It begins just off the Whitestone Bridge and goes north through the Bronx into Westchester County.It is designed for passenger cars only; no trucks or buses are permitted on this road. The reason for this is that there are a few low bridges on this highway, and 18 wheelers just can't clear them. The most notable of all is the Westchester Avenue Bridge, seen above facing North.As you can see, there is a posted clearance of 10' 4'' and as evidenced by the damage to the underside of the bridge,alot of trucks foolishly tried to squeeze underneath. Let me discuss a few examples of this if I may.
    The problem basically is that truckers exiting the Whitestone Bridge often wander onto the Northbound Hutch instead of 95 North or South.About 3 miles north on the Hutch is the foreboding Westchester Avenue Bridge,seen below.
    Above: This out of town trucker brought his rig onto the Northbound Hutch and whacked the Westchester Ave overpass. It seems it was the drivers first day driving for this company,which was based in FL. He was unaware that he was not allowed on the Hutch, and ripped his trailer to shreds. He bolted out of the cab and ran from the scene before police arrived, so it would be safe to say he no longer works for that trucking company. As many of you know, the Westchester Ave bridge is quite low on both sides--the Northbound side has a 10'6'' clearance and it is not uncommon for truckers to come off the whitestone Bridge and wander onto the Hutch. NYC put up 17 signs before this low bridge, warning truckers to get off the parkway, yet truckers continued to hit the bridge. The next idea was to put a series of lights on the base of the arch, and the idea was that truckers driving at night would see these lights and stop in time. The actual result was that every light was knocked off the bridge by misplaced truckers. OK, so what does the city do? They spend an enormous amount of money and install a ''overheight vehicle sensor warning system''. Essentially a sensor has been embedded at the side of the road and calibrated to a specific height, lets say 9'2''. Anytime a vehicle higher then 9' 2'' passes the sensor, it triggers a HUGE sign that is suspended across the highway that says something like ''YOU ARE OVERHEIGHT!! EXIT 100 FEET LOW BRIDGE AHEAD!!''
    [​IMG] The sign,seen above, is similar to the ones in Yankee Stadium or on the Whitestone Bridge.It is red and really bright and I cannot hazard a guess how much money was squandered on this system, but it went into operation on or about January 2004. For a few months all was quiet, but this morning as I approached the Westchester ave bridge I saw that the top of a trailer had been peeled off and was lying next to the roadway.This was a fresh acident, having happened less then 24 hours ago!! Can you believe that truckers are ignoring that new million dollar sensor? [​IMG]
  7. nighthunter1981
    nighthunter1981 Bobtail Member
    16
    Aug 25, 2008
    imler,pa
    Yea herd that new york is tough to learn i run it if i have to but since i just bought the new truck i have its a little rough to go over there~its 300 wheel base ~lil long and i herd here in the past month they started enforcing the 55ft rule again any trucks over 55ft need permited i know a few guys that got fined for this in the last month anyway all i can say is not every1 is cut out for nyc ~ive been in every major city in the us and nyc pretty much is the worst on my opinion~but its not actually that bad when u get to know it ~
    BrickEddie and imouthousejr Thank this.
  8. stormking
    stormking Bobtail Member
    25
    10
    Jun 12, 2008
    Ithaca, NY
    imouthousejr, MACK E-6, Baack and 3 others Thank this.
  9. User Name
    User Name Light Load Member
    143
    36
    Aug 20, 2008
    Midwest
    It looks to be somewhat higher then the posted 10'-6" since it looks like the cab cleared... not that it matters. A panicking driver makes some really bad decisions, it could have been posted 6'-6" & many will try it.
  10. CornCob
    63
    53
    Aug 8, 2008
    Bayville, NJ
    I think that they mark the overpasses a foot lower than they really are in NYC. I always remember that on the BQE, I-278, by Atlantic Ave, it was marked 12'6" or 12'8" and 13'6" could clear it.
    Here's another link on Parkways from NYSDOT:
    https://www.nysdot.gov/portal/page/portal/divisions/operating/osss/repository/parkway%20truck%20brochure.pdf
  11. nighthunter1981
    16
    Aug 25, 2008
    imler,pa
    yea the nyc goes from your center of ur axel so they are a foot under what they are most of them not all lol
