Hey all you fellow heavy haulers,
Just curious if any of you have experience with the onboard wireless scale system offered by Truck Weight?
Have looked at them online & spoke to them about their system. Basically a sensor per axle group, retail is $499 per sensor & the handheld controller is $499, but they will cut a deal, quoted me at $400 per sensor & the same for the handheld.
Supposedly good within 1% per axle group & it uses a virtual sensor for the steers, whatever that means. The sensors are suppose to be good up to 100k per axle group also.
Truck Weight Wireless Onboard Scale System
Discussion in 'Heavy Haul Trucking Forum' started by soloflyr, Aug 18, 2015.
Page 1 of 3
Unless convenience is super important to you, you can just mount an air pressure gauge on an airbag at each axle.
As for the steer "virtual" steer sensor -- it just estimates based on your drive weight & calibration setting.Last edited: Aug 18, 2015
Dominick253 and soloflyr Thank this. -
Kind of figured that was the way the virtual sensor worked. They make sensors for air & spring systems so it would seem to me that it would make more sense to just get an actual sensor for the steers. -
You will only need one sensor per group, not individual axles. All 4 air bags are tied together in a tandem application, so there will be no difference between the front and rear axle for example.
Special Note:
*PROPERLY calibrated means you must resist the urge to think "Well you know super trucker, if I pad the loaded weight just a little, then I'll always be good."
Avoid this thought process, remember, the sensors measure PSI in 1/64ths...so let's say your loaded weight is at 40,000lbs at 72PSI...72 * 64= 4608 units to the computer, so even a small increase for "padding" throws future calculations way out of whack.
Calibrate it properly, and then pad the weight a little from the display.
Also, good calibration practices are to calibrate on a known accurate scale, use the same scale for both the loaded and empty weights as it removes even small variances, which as I've shown can reduce accuracy.HeWhoMustNotBeNamed and soloflyr Thank this. -
Since you are obviously well versed on this I have a question, I just ordered a new truck single rear axle but with an Air Weigh three way gauge setup, I will be pulling a single axle trailer, so am I correct to assume that with an air ride ft axle I will be able to get actual weights on all three axles, correct?
Thx Stan -
Thank you for your reply Heavy Hammer.
Good info helps make a good decision. -
I went with this for 100.00 and put the sensors in trailer and drive axle airbags. Lets me know before leaving the parking lot if I'm legal or not.
http://www.amazon.com/GlowShift-Bla...439945751&sr=8-2&keywords=air+suspension+dual
I'd love to have the air weigh, but if trailer bags are reading over 94 PSI in my cab.... time for a rework !soloflyr Thanks this. -
I've seen some trucks, mainly low beds, that use a pair of load cells bolted to the frame and the 5th wheel pivot pins pin to them. Something like that should give you an accurate reading of your drive weights and if you've got the 5th wheel positioned correctly your steer weights should be legal as well. I'll see if I can find a link.
www.Vishaypg.com/onboard-weighing/forestry-logging/9150-meter/
Click on the 5th wheel system link on the lower right part of the page. We've been using that setup for decades in logging on trucks and trailers since you're paid by weight, so you want to be as close to legal as you can.soloflyr Thanks this. -
Page 1 of 3
