Volvo 780 front air bags deflating
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hunts2much, Jan 26, 2011.
  1. hunts2much
    hunts2much Medium Load Member
    303
    Thanks Received:
    98
    Aug 25, 2008
    I drive a Volvo 780 which has air bags on the steer axle. After the truck has been shut off for a few hours BOTH bags completely deflate. I can not see (soapy water and spray bottle) nor here where the air is leaking from. They both inflate quickly when I start the truck and the compressor has no problem keeping them inflated but I would like to get this fixed IMMEDIATELY before I get placed oos.
    Anybody have any suggestions to help me locate the leak?
  2. Trouble65
    Trouble65 Medium Load Member
    621
    Thanks Received:
    136
    Jan 11, 2009
    Ontario Canada
    Follow the lines and spray water on each connection. Also check the front suspension air ride leveling valve.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,344
    Thanks Received:
    1,381
    Oct 11, 2010
    Borispol, Ukraine
    Is your truck with ECAS ore just levelling valve on front axe?
  4. hunts2much
    303
    Thanks Received:
    98
    Aug 25, 2008
    Not sure what ECAS is but it does have a leveling valve on the front, which is less than a month old.
  5. Pablo-UA
    7,344
    Thanks Received:
    1,381
    Oct 11, 2010
    Borispol, Ukraine
    sometimes levelling valve looses air and no sssss sound. so the only way is to get bottle with soap water and find problem from underneath
  6. me myself and I
    me myself and I Medium Load Member
    317
    Thanks Received:
    80
    Oct 5, 2009
    vernon hills,Il
    Check air tanks. Thats what happened to me. Front tank was leaking thru bad weld.
    hunts2much Thanks this.
  7. Add a truck driving job review
  8. Pablo-UA
    7,344
    Thanks Received:
    1,381
    Oct 11, 2010
    Borispol, Ukraine
    Do not fix tank with welding yourself. Just advice
  9. heavyhaulerss
    3,301
    Thanks Received:
    1,582
    Dec 23, 2009
    AL/TN BORDER
    Let J.B. weld it for ya. :biggrin_2559:
    josh.c and hunts2much Thank this.
  10. josh.c
    josh.c Road Train Member
    1,105
    Thanks Received:
    412
    Feb 22, 2009
    Knoxville, Tn
    Make sure you get the five-minute kind though, 'cause you gotta go!:biggrin_2559:
  11. MedicineMan
    MedicineMan Road Train Member
    5,792
    Thanks Received:
    6,403
    Jan 13, 2007
    Woodville, TX
    the bags going flat after a few HOURS is not an OOS violation. the only oos violation is if there was an audable leak bad enough that the compressor couldn't keep up
  • Draft saved Draft deleted
