volvo 780 w/ d13 485hp and I shift tranny.
Discussion in 'Volvo Forum' started by rider2002, May 12, 2013.
  1. rider2002
    rider2002 Light Load Member
    52
    Thanks Received:
    Dec 20, 2009
    San Tan Valley, AZ.
    Hi Guys, I,m looking into buying a 780 with D13 485 hp engine w/ Ishift transmission. 545,000 miles, has generator on it also. the year is 2008. What kind of fuel mpg,s can i expect. And what kind of issues should i expect for this st up. I haul household funiture so not to heavy. Run cal,or,wa,az,nv, any info would be helpfull. thanks.
  2. Bakerman
    Bakerman Road Train Member
    1,540
    Thanks Received:
    1,714
    Jan 27, 2013
    Phoenix, AZ
    I would find something with fewer electronics on it, Vanguard here in Phx sure doesn't know how to work on them!! If you do get it, better find a very good mechanic.
  3. fortycalglock
    fortycalglock Road Train Member
    5,432
    Thanks Received:
    4,786
    Jun 25, 2011
    Tourist Town, FL
    Have the ECM downloaded and that will tell the worst case fuel mileage since you're a bedbugger. We can all guess all day long, but there's no reason to since you have 500,000 miles of data.
  4. Johny41
    Johny41 Medium Load Member
    490
    Thanks Received:
    190
    Feb 10, 2011
    Ontario
    My dash yesterday , at the end of my trip from Ontario, Canada to Laredo,Tx / light load 13,000 lbs/ Volvo 780. ,2008,/D13/ 13 Eaton manual; original motor.
  5. rider2002
    52
    Thanks Received:
    Dec 20, 2009
    San Tan Valley, AZ.
    Thanks Guys, Not getting the truck from vanguard in phoenix. They don,t seem to know anything there. Dealer is TEC. in Seattle. Hope to see good results with this truck.
  6. flood
    flood Road Train Member
    2,315
    Thanks Received:
    1,078
    Dec 25, 2010
    only real DOWN SIDE is the D13..... 1st only volvo can work on it ..... 2nd MAKE SURE it's had all the upgrades done to the head....... the 2008 D13 had major problems with injector cups (cracking every 75k-100k miles) our had 4 set go bad in 260K
    us xpress stopped getting volvo's because ALL 1,500 2008s had this problem...... i know they fixed it just make sure this truck has had the fix done
  7. VolvoVNLTrucker
    VolvoVNLTrucker Bobtail Member
    34
    Thanks Received:
    14
    May 12, 2013
    Sir, I'm new to the forum and own exactly what you are looking at - 2008 seems to be a watershed year for Volvo as far as problems are concerned. First of all, at that mileage - and if you can afford it - have a independent mechanic diagnose the IShift tranny and check the condition of the Idler gears - Those IShifts tend to deteriorate in both performance and components are starting to wear past minimums and will be problematic. I just replaced mine at a cost of $15,000+. The bull gears: Gear walk-off is an issue with these engines and the repairs are pricey $19-20,000 and it is common in Volvo engines. (there was a recall of sorts for certain incidents involving those gears and volvo engines; you might be able to get it fixed for free...)
    Check and replace (or have replaced:)
    - Fan clutch
    - Electronic harness (These engines have a tendency to develop an oil leak right where at the harness port and will contaminate the harness and you will have major problems)
    - Axle and Leaf springs - these will develop hairline cracks over time and will break. Undectable unless spotted by mech and VERY DANGEROUS (axle movement)
    - Charge Air Cooler - has a tendency to rub up against other parts of the radiator frame and wear a hole in it. Check...
    Good Luck!
  8. vikingswen
    vikingswen Road Train Member
    1,262
    Thanks Received:
    1,387
    Jun 14, 2012
    In the Stratosphere
    Be careful with the old Husky shop in Seattle. Seems like everything they touch is screwed up. They were supposed to do the engine recall with the gears and never did that and had to rebuilt the engine instead since it failed on our oldest one. I hope it is getting better since TEC took it over, but we had tons of trouble with that shop and use the TEC shop in Tacoma now. I had a good experience with the Wilsonville OR shop before.
    Make sure you have the option for Eco-Roll and the E/P button to change the shift pattern for the hills on the I-shift. Seems like I could easily get a mile per gallon more with the 2013 than the 2011. Both are D-13 500hp with the I-shift. The 13 has 3:36 gears and the 11 has 3:25 gears, but does not have the Eco-roll and the E/P shift option.
    Like mentioned before have them do an ECM dump, check that all recalls are done and do some oil sampling. We lost the tranny in the one below, but that was due to lack of oil. The truck was in a head on collision and after they fixed the truck they did not add oil to the transmission and it did not get very far from the body shop since it is a pressure lubricated transmission.
    Good luck
  9. Gentlemanfarmer
    Gentlemanfarmer Light Load Member
    235
    Thanks Received:
    207
    Feb 26, 2010
    Sumterville, FL
    I have a two week old 2014 Volvo 780, D13 455 hp, I-Shift XE package and couldn't have asked for a better, smoother, quieter, powerful truck. I pull a flatbed and the truck acts like I am pulling air even with a 45,000 lb load. It cruises at 65 mph at 1100 rpm and gets over 7 mpg. I have gotten over 8 mpg empty at 70 mph!
    The reason I bought the truck was that my 2007 Volvo 780 crapped out on me. I put over $35,000 in repairs in the past two years and when it blew the air compressor, cooling system and air dryer, I'd had enough. The new truck is beyond belief in ride and comfort. All my pertinent controls, including jake brake are on the steering column. The radio comes standard with Sirius or XM, weather, and the controls are on the steering wheel. Blue tooth is standard. Built in 3.2 cu ft refrigerator, factory installed Xantrex 1000 watt inverter/charger. Factory installed shore power outlet. All fairings can be removed for easy access under the truck.
    If you are looking for a new truck, I strongly recommend the Volvo 780 with I-shift.
    davidtruckervan and xiipercent Thank this.
  10. rider2002
    52
    Thanks Received:
    Dec 20, 2009
    San Tan Valley, AZ.
    Thanks Guys, Good info i had them check the injectors already. they said they were changed about 200,000 miles ago. I,ll HAVE them check on the other stuff tomarrow.
  • Draft saved Draft deleted
