Volvo D-16 problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sandlapper, Apr 13, 2009.
  1. Sandlapper
    Sandlapper Light Load Member
    208
    Thanks Received:
    31
    Feb 6, 2008
    Simpsonville, SC
    This thread is for owners of Volvo D16 engines. A number of driver's are having problems with this engine. I and several other D16 owners want to gather information as to the problems you may have experienced with this engine for a possible class action lawsuit.
  2. Sandlapper
    208
    Thanks Received:
    31
    Feb 6, 2008
    Simpsonville, SC
    I have 335000 miles on my engine and am on my third turbo. The engine recently had an overhead done and is using a gallon of oil every 1000 miles. I get an ECM failure alarm when turbo boost is 45psi and pyrometer is at 600 degrees. Under light loads 10 to 20k lbs between 45 and 60mph I get a vibration. I dont know where it is coming from but it is driving me crazy.
  3. vangtransport
    vangtransport Medium Load Member
    479
    Thanks Received:
    194
    Apr 14, 2009
    :biggrin_25510:I have had and still have to many problems to list. We all need to get together and swap info. 2006 D16 600 115,000 miles. In shop at least 20 times.
  4. black_dog106
    black_dog106 Road Train Member
    1,402
    Thanks Received:
    469
    Mar 29, 2009
    Shelburne Falls, MA
    ####, that is 5750 mile average between shop visit...:biggrin_25512:
  5. vangtransport
    479
    Thanks Received:
    194
    Apr 14, 2009
    I know, the real sad part about it is the time that they have the truck. At first I would get the truck back in 1-3 days, now it is going on 2 weeks. Volvo claims to have the problem diagnosed in 2 hours, well I dropped my truck off last Tuesday and I got my answer today.
  6. black_dog106
    1,402
    Thanks Received:
    469
    Mar 29, 2009
    Shelburne Falls, MA
    gezus.........:biggrin_25512:
    Tell the bank your truck is in the shop again , im sure they will be understanding as to why your not making your payment this month
  7. Add a truck driving job review
  8. DonKingKong
    DonKingKong Bobtail Member
    Thanks Received:
    Jan 1, 2009
    Edmonton, Alberta, Canada
    As far as the turbo goes on the D16, the turbo itself isn't failing like a traditional turbo fails, since it's a variable geometry turbocharger, the sliding nozzle turbine can seize up to the point where the actuator can't move it anymore, so it throws a fault and the engine can run like crap, if the actuator is stuck in a certain position. I wouldn't blame it entirely on Volvo, Holset the turbo manufacturer should take some blame, if not all for this design problem. Also the D16 uses the exact same turbo as the Cummins ISX and they themselves are feeling this problem.
  9. JWK1988
    JWK1988 Bobtail Member
    Thanks Received:
    Dec 13, 2009
    Actually holset is the builds the turbo the the housing and design are entirely volvo's. Thats why the isx engine dosent have the same problem.
  10. vegetto
    vegetto Bobtail Member
    20
    Thanks Received:
    Dec 14, 2006
    Holset should take none of the blame. Cummins owns Holset....try looking it up some time. Holset builds the turbo to Volvo's specs....it isn't their fault.
    I work here at a local Volvo and these new Volvo engines including the D16 are all having turbo, injector, injector sleeves, heads, and piston problems. The minor stuff is egr valves, breaking exhaust bolts, breaking intake bolts, and multiple oil leaks including the cam position sensor, injector harness, valve cover, and oil filter housing.
    I may be bias because I work at Volvo......but I mostly work on Cummins here and I hardly see any major problems with Cummins engines.
  11. damon66us
    damon66us Bobtail Member
    Thanks Received:
    Sep 19, 2010
    Federal Way,Wa.
    880 D-16 600 Hp.Lots of problems here too.5 times injector cups(last time got new s/s conical cups+new injectors),new turbo,wire harness,ECU,EGR,jake brakes,fuel pump.Bought Feb 2009,11000mi and in 18 months they had my keys for 5 months.Count me in if there's any lawsuit going on.
  • Draft saved Draft deleted
