On my Acert I have what appears to be a little oil that has come out the weep hole on the water pump. No noticeable water in the oil though. Water pump on its last leg?
Water pump going out?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Aug 1, 2015.
I'd schedule it to get changed. A little coolant seeping is normal, but every time I've seen oil there, the oil sample came back with indications of coolant in the oil (elevated potassium and sodium) and cleared up once we put a water pump on it.
Oscar the KW Thanks this. -
Bad thing is I'm trading the truck off in 3 weeks.
Ruthless Thanks this. -
You've only had that truck what....1 1/2 years? ........
Spray some brake cleaner on it and see if it reappears.
With three weeks to go I'd leave it alone unless necessary.Oscar the KW Thanks this. -
I might be wrong but its usually antifreeze that comes out of the water pumps weeping hole. They can "weep" for quite sometime .
One guy I know went close to a year with it leaking out like that. In his case after all the antifreeze he added he could of fixed it. -
MJ1657 and Oscar the KW Thank this.
I've never heard of a water pump that gets oiled. Whether it was a car, light truck, or the Mack, they've always just had water flowing through them. Never owned a Cat, though...so maybe they're just weird.
