will a truck with 2.64 gears pull?
Discussion in 'Ask An Owner Operator' started by Evilcapitalist, Nov 3, 2008.
  1. Evilcapitalist
    Evilcapitalist Light Load Member
    143
    Thanks Received:
    146
    Oct 14, 2008
    Aiken,SC
    I was looking at some Internationals today that had 2.64, 2.79, 3.36 ratio gears. These trucks might get good fuel mileage, but would they pull? Engine is 435 Cummins ISX in most of these? Thanks for your input!!!
  2. sgreer78
    sgreer78 Light Load Member
    250
    Thanks Received:
    43
    Jul 26, 2008
    St Louis, MO
    It would depend on the transmission. Odds are, if they were specs with those high gears, they are direct drive. Schnider, Maverick, and Swift do this. With that many trucks spec'd like that, it can't be that bad.
  3. Bigray
    Bigray Road Train Member
    1,133
    Thanks Received:
    367
    Nov 23, 2007
    Tampa, Florida
    Evil, i too am looking at trucks, imo the lowest gear i am willing to consider is a 3.36 ratio, otherwise i feel i would have to drop gears to stay/be in the proper rpm range in the slower states, or run faster than i want to too be in the range thus defeating my goal of good mpg. just my opinion.
  4. MedicineMan
    MedicineMan Road Train Member
    5,792
    Thanks Received:
    6,403
    Jan 13, 2007
    Woodville, TX
    you are looking at 3.36's with an overdrive. he's looking at 2.64's with a directdrive transmision. in the end it's the same basically but you get to use a direct drive which tends to be a stronger transmision for all the rookies they hire to tear up.
    EC you need to get the model of the trans and run that number to find the first gear ratio and use that to figure out the overall first gear ratio at the ground. then do the same for a truck with a more typical gear setup to compare them.
    Lots of times those truck will be set up with a 9 or 10 speed with a very low first gear
  5. Markvfl
    Markvfl Road Train Member
    1,106
    Thanks Received:
    317
    Nov 29, 2007
    Apopka, FL
    Yeah, you need the low gear to get rolling and get started on a grade. I read somewhere that a higher rear end ratio with a direct trans has a lower drag co efficient and robs less power from the drive train. My gut tells me that a higher ratio with an overdrive trans is more practical and will pull much better. There are smarter guys who spec these trucks for high mileage and low maintenance and the setups you describe are their choices. I'm sure you'll get sum tech experts to reply with the scientific answer.
  6. bowhunter3125
    bowhunter3125 Light Load Member
    126
    Thanks Received:
    15
    Oct 15, 2008
    klamath falls Or
    the last international i drove had a Detroit 60 with 3:36's and a 10 speed, it pulled real nice, but as medicine man said, it has a very low first gear
  7. Add a truck driving job review
  8. 1989 Pete
    1989 Pete "Pine Tree Eater"
    586
    Thanks Received:
    42
    Mar 14, 2008
    Logging Country South Georgia
    From what I'm told around here the higher the gear the better the pulling ....the higher the gear the more fuel you suck
  9. HIDIVE
    HIDIVE Light Load Member
    85
    Thanks Received:
    24
    May 15, 2008
    McCoy, Va
    The higher the numbers the lower the ratio.
  10. C16KIWI
    C16KIWI Medium Load Member
    579
    Thanks Received:
    135
    Jun 14, 2008
    New Zealand
    WOW I did'nt know you could get a ratio that low,over here I would never get out of low range.
  11. 550hpW900L
    550hpW900L Road Train Member
    1,872
    Thanks Received:
    1,063
    Jan 29, 2008
    norcal
    Put the big injectors back in when the warranty is up, hell ill even call you and walk you through it then you wont have no problems! :biggrin_255:
  • Draft saved Draft deleted
