‘93 W9 8 bag suspension not fully pressurized
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Aug 26, 2026.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,427
    1,741
    Dec 4, 2019
    Seems like the front two bags are getting 90%, the rear two on the front axle are 80% and the four rear axle bags, might be 50%. I don’t hear any leaks in the cab or outside. Can switch dumps air fine and when switched to “raise”, it starts to fill but doesn’t complete.
    OLDSKOOLERnWV Thanks this.
  3. Big Road Skateboard
    8,026
    47,126
    May 2, 2021
    Is the rod for the leveling valve at 90*?
    mile marker 27, Magoo1968 and Bean Jr. Thank this.
  4. mile marker 27
    1,427
    1,741
    Dec 4, 2019
    I apologize but I’m not at the truck, at the moment. Only valves I saw were the leveling valve and a valve that’s supplied air from the leveling valve. After that, all bags are basically linked together. I really don’t understand why I’m seeing what I’m seeing, with the front bags having more air than the rest. Shouldn’t they be equalized?
  5. Big Road Skateboard
    8,026
    47,126
    May 2, 2021
    I'm assuming you're empty, or bobtail? Yeah, they're all the same. Are you just gauging off of feel?
    You mentioned it lowers and raises with the dump. Did you have the brakes released?
  6. mile marker 27
    1,427
    1,741
    Dec 4, 2019
    Yeah, I’m gauging off feel and looks. Fronts, look and feel much tighter.
    I dropped from an end dump and hooked to a hopper that I haven’t pulled since February. I tried it with brakes released, as well.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,191
    5,859
    Mar 18, 2021
    St Malo mb
    Does the truck sit level ? I vaguely remember a older t600 with the 8 bag system I drove for a bit the back was lower than the front so airbags appeared different to have different inflations but it drove smooth..
    mile marker 27 Thanks this.
  8. mile marker 27
    1,427
    1,741
    Dec 4, 2019
    Never noticed it to be unlevel.
  9. OLDSKOOLERnWV
    20,365
    307,421
    What kind of leveling valve do you have? (Picture)? Is there 1 leveling valve or 2?
  10. mile marker 27
    1,427
    1,741
    Dec 4, 2019
    I’ll have to get a pic of it this afternoon. There’s one valve with linkage to the back of the rear differential, that has air supplied from up from tanks. That valve has a line coming from it, going to a small valve on the left frame rail, that then supplies air to all 8 bags.
  11. Big Road Skateboard
    8,026
    47,126
    May 2, 2021
    I would think the small valve is your dump valve. Pics of both valves would help, and maybe pic of the truck from the side when inflated, and the leveling valve pic when inflated.
