06 Frlnr classic xl need diagram for cab air bags/leveling arm
Discussion in 'Freightliner Forum' started by Stonegirl, Nov 8, 2024.
  1. Stonegirl
    Stonegirl Bobtail Member
    11
    5
    Jun 14, 2021
    So I've had to replace the cab air bags and shocks and there wasn't even a leveling arm on the leveler. Now it rides like #### i see why they call em freightshakers now ..I've found an older freightliner and stole the arm off it (i live in middle of nowhere..gotta do what I gotta do lol) but I don't know why it still lets the bags totally deflate when my truck is off, bumpy ride.. is the arm maybe the wrong height or bad valve? Also if anyone can donate the air line routing diagram for the air gauges in the dash i have a huge leak on 1 of the push to connect fittings and I cut new line still leaks.. or maybe the parts # for ill add a picture.
  3. RocketyMan
    RocketyMan Medium Load Member
    541
    319
    Jun 5, 2015
    If you post last 6 of VIN I can look up what your truck came with stock air suspension with the airing schematic.
  4. Stonegirl
    11
    5
    Jun 14, 2021
    1FUJAPAV06DU25619
  5. RocketyMan
    541
    319
    Jun 5, 2015
    Here is what I found for your stock configuration.
    Sometimes the welded mounting point on the rear of the pumpkin breaks off. This basically gives the picture of what the airbags should be when the level is normal:
    Your arm should be 345mm long:
    I attached your airing schematic too.
