1 wheel locks up when breaking help!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thesvg, Feb 16, 2011.
  1. thesvg
    thesvg Light Load Member
    Dec 9, 2010
    192
    Thanks Received:
    13
    Hey guys I'm just about to go madd here, when I brake my last axles wheel on the right side locks up, I have swapped service lines to the other chamber to see if the problem followed and nothing. Then I swapped the slack adjuster and nothing.... I'm just about out of ideas, has anyone ever had this problem?
    Thanks in advance
  2. mgfg
    mgfg Road Train Member
    Mar 29, 2010
    1,753
    Thanks Received:
    626
    ABS sensor.
  3. thesvg
    Dec 9, 2010
    192
    Thanks Received:
    13
    It's non abs
  4. canuck in da truck
    canuck in da truck Road Train Member
    Aug 6, 2010
    4,352
    Thanks Received:
    2,601
    western pa
    i would think it might be your relay valve /air valve on that axle--had the same happen to me--everytime i made a brake application over--about 15 lbs the wheel on trailer would lock up--only way to cure it was to release the air from the brakes--push buttons back in and away we go--and just try to brake very gently ---makes for a long trip to boston and back--but if you swapped service lines --should have moved to other side
  5. canuck in da truck
    Aug 6, 2010
    4,352
    Thanks Received:
    2,601
    western pa
    abs sensor generally only tells the ecu what the rate is that the wheel is spinning--and compares it to the others to see if there is wheel spin happening
  6. geargrinder78
    geargrinder78 Bobtail Member
    Jan 4, 2011
    7
    Thanks Received:
    IL
    if the brakes are in adjustment,check the s-cam to make sure it hasnt rolled over.
  7. DumpTrucker
    DumpTrucker Bobtail Member
    Sep 3, 2007
    30
    Thanks Received:
    Joplin MO
    Could be a warped drum?
  8. thesvg
    Dec 9, 2010
    192
    Thanks Received:
    13
    Yes I am having sort of the same thing except, when the wheel locks I just release the pedal and it spins again
  9. Diesel Dave
    Jan 20, 2010
    8,684
    Thanks Received:
    24,696
    Hesperia, Ca.
    The same thing happen to me years back, it was the RELAY VALVE, this was on my trailer
  10. canuck in da truck
    Aug 6, 2010
    4,352
    Thanks Received:
    2,601
    western pa
    and it is embarrasing as hell
    heyyyy maybe try and adjust all the brakes--make sure they are all equal
    it sounds like an air issue cause as soon as you take your foot off it rolls again--but like the other guy said a brake drum might do that as well
