Got a 12.7 detroit that will randomly smoke white like a freight train only on startup for a couple seconds then runs fine seems to be coolant because it loses a little but it only does it once every few days also my coolant tank will be bone dry after driving coolant temp is fine doesn't overheat low light doesn't come on take the cap off and relieve pressure and the coolant will come back up any ideas on my issue?
12.7 burning coolant on startup sometimes???
Discussion in 'Ask An Owner Operator' started by Klantz, Sep 18, 2024.
Page 1 of 3
Head gasket time. Coolant in burning in the cylinders. If your coolant is low and your low level light is not coming on, you need get that fixed also.
77fib77, Rideandrepair and Bean Jr. Thank this. -
Definitely a head gasket. Why it only does it at startup, I dunno.
Rideandrepair, Bean Jr. and blairandgretchen Thank this. -
Does the exhaust smell like coolant or like raw fuel when it smokes?
Rideandrepair Thanks this. -
blairandgretchen and Rideandrepair Thank this.
IDK, but it sounds normal to me,
For the purpose of this discussion define ''low'' coolant.
The Puke tank should be MT when hot and when you release the pressure the coolant returns to the puke tank.
How does the pressure build if the head gasket is blown?
Any air bubbles in the puke tank right after high boost?
White smoke on start up is normal when the computer is in enrichment mode,Rideandrepair Thanks this. -
77fib77, blairandgretchen and Rideandrepair Thank this.
Page 1 of 3
