Its a 2001 Detroit 12.7 factory was a 430/500hp and now its supposedly set to 470 straight. Looks to be the factory gated Garrett part number 23528059 and leaks oil at the shaft out the exhaust if idling for a bit.
I haul light, total weight of truck and freight is like 30k lbs, and my current mpg loaded is about average 8-8.5 unless in the mountains then its about 7ish.
Ive tried different speeds 64-70 and all are about the same. high gear in the 13 speed isnt much rpm difference.
Without a different tune in the ECM is there a better turbo that would yield me better mpg? I dont plan on turning the power up ever. Since i have to replace the turbo anyway, i was curious if i could squeak a bit more mpg out of it somehow. What is the smallest ungated borg warner that can be ran without having to watch it and make sure it doesnt overboost? Or just replace it with the same factory one? Really trying to maximize mpgs the best i can.
Thanks.
12.7 Detroit need a new turbo (upgrade?), hauling light and best mpg?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Green461, Mar 24, 2020.
Page 1 of 15
171701 would work nice at that hp level.
Should free up the exhaust flow nicely.jamespmack Thanks this. -
From what i can find the stock garrett is 74mm compressor wheel and a 82mm exhaust... ? thats just from some forum.
And that 171701 is a 71mm/88mm ?
Would this have similar driving/spooling characteristics as the stock one? less or more lag?
Thanks. -
Compressor
71mm inducer
100mm exducer
Exhaust 88mm exducer
96mm inducer.
Its basically the same turbo as the 171702 just the 71 mm inducer is smaller then the 171702 75mm.
I don't think lag will be that bad. Your stock Garrett will spool faster and have better jake performance. Trade offs to everything. I think MPG will be better overall with the 171701 from less back pressure. -
With those 2 being the same exhaust wheels, what would the compressor side differences do? Would the larger 75mm move more air faster? Less lag? The compressor wheel on the factory garret is what im not sure on the size, 74mm maybe? Im just curious the characteristics of the larger difference in size from exhaust side to compressor, the 171701 has a way larger gap, not sure if that is relevant or not. ?
The K31 is similar in size to the 171701 but spools up much faster and the jakes work much better with it. It's wastegated but that's the reason it performs so much better.
DUNE-T Thanks this. -
The K31 (Borg warners direct replacement 172743) im sure would spool faster and perform better, with hauling super light a little lag probably wont hurt me, better MPG is the goal. Just curious the difference between the 171701 and 171702? drivability wise. I'll trade a little lag for mpg.
Im curious what stops an ungated turbo from overboosting? Sizing it correctly? -
Proper sizing is what prevents any turbo from overboosting but you can do that with any turbo, wastegated or not. I see guys posting videos all the time running 171702s up to and over 50psi. At that point the drive pressure goes nuts on those 1.32 housings. -
Anyone have the specs to the Garrett 23528059 ? Really curious on the difference between it and the K31
Page 1 of 15
