12.7 no heat
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by nikmirbre, Aug 9, 2020.
  1. nikmirbre
    nikmirbre Road Train Member
    5,057
    8,718
    Jul 27, 2011
    High Point NC
    B420367B-5363-4CFA-A655-43DDC757AFAC.jpeg 40A10DA3-8FA5-4133-9915-FBD1BFA94AB5.jpeg
    As title says no heat. I needed it this morning to help defog my windows. I thought I would turn the valves and it would help but none whatsoever. The 2nd picture, I turned that valve and coolant started pouring out of it.
    Rideandrepair Thanks this.
  3. nikmirbre
    5,057
    8,718
    Jul 27, 2011
    High Point NC
  4. AModelCat
    145,350
    If the line going to the core is hot and the return from the core is cold, there's likely a blockage somewhere.
  5. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    Those valves are in the open position, so I’d agree on a possible blockage.
    Coolant shouldn’t pour out of a valve, so I’d assume that one is seized/broken/faulty.
    The one out of the head - does it go to transmission cooler? Leave that one alone.
    Dino soar, Rideandrepair and nikmirbre Thank this.
  6. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    Try replacing with these style valves.
    Dino soar, Banker, 650cat425 and 2 others Thank this.
  7. nikmirbre
    5,057
    8,718
    Jul 27, 2011
    High Point NC
    I agree with blockage. How/where would I start??
  8. nikmirbre
    5,057
    8,718
    Jul 27, 2011
    High Point NC
    Yea it’s the valve is bad on that one. And yes my last Detroit had those style valves and I like those better! Gonna fix it this weekend to give me something to do
  9. AModelCat
    145,350
    Usual suspect would be the water valve that regulates the coolant flow through the core. Those 1/4 turn valves could be stripped and not fully open too.
    Next suspect would be the heater core itself being plugged up.
    Dino soar, Bean Jr., magoo68 and 3 others Thank this.
  10. bad-luck
    bad-luck Road Train Member
    3,023
    5,437
    Nov 16, 2013
    Baltimore, Maryland
    I don't remember how the heater core is set up, it's been years since I have owned a freightliner. But check to make sure the valve that is controlled by the climate control is opening
  11. nikmirbre
    5,057
    8,718
    Jul 27, 2011
    High Point NC
    This is a w900 glider.....
